- 25 Mar 2004
- Fareham
No the service tags are tracked, they'll know the one they sent you is a warranty replacement and you'll get the remainder assigned to it.
Ah fair enough. I wasn't sure myself as repairtech just sent me a brand new monitor as my old/faulty unit became EOL around 2 1/2 years into the warranty.No the service tags are tracked, they'll know the one they sent you is a warranty replacement and you'll get the remainder assigned to it.
I'm seriously not worried and as you state their tests, like the burn in ones, are unrealisticYou likely have little to worry about to be honest.
From the tests they've done and shown in the "reflections" section, from what I can tell looking at the images, comparing the AW3423DW to the AW3423DWF I have in front of me (that they use for those average room shots); using the central arm holder which is the same colour on both (black, or black without any direct light on them), as it's white on the exterior of the DW and it's black on the F so can't compare those (and the DW white is more reflective). It clear that it really is more of a VERY bright office room or outside daylight (at noon) in a pure white almost reflective room (check out that table it's on they're using, it's reflective as a mirror, one of the reasons I dinged the MSI for that RGB bar at the bottom) that is causing the raised blacks on the screen by reflecting it "towards" the screen itself. Basically, it's everything that can be done to reflect light onto a screen, and not just any light, but very strong light and it also has a red hue.
A VERY unrealistic scenario given users of this monitor know very well what needs to be done to prevent issues; given if you just want to game or normal office work, you don't go QD-OLED, you go for the other screens. And in most cases, not even most offices are THAT bright, white and reflective. And in those cases, don't use a white light that is more on the lower end of the K scale.
So in your case, you're unlikely to see it, because unless if you open the blinds AND paint your ENTIRE room white (pure, and using a more reflective kind of paint), our screens (not just the Samsung) is unlikely to exhibit this issue directly.
They've basically shown an edge case scenario in case there's any nutters out there in such a setup and grabs it. Not for normal users.![]()
No it will work great with a 4090, it supports Freesync anyway. cpu has nothing to do with it.so as this monitor AW3423DWF has AMD freesync, is it not ideal for the 4090 wiht an intel cpu?
Use code Telegraph8MON brings it down to £812, i just ordered oneApparently, a Dell Advantage code knocked 20% off the DWF most likely by mistake haha. I presume this has been pulled.
Use code Telegraph8MON brings it down to £812, i just ordered one![]()
VA = pukeTempted even though I received a brand new VA monitor recently as an RMA replacement![]()
go for it i have been lurking here for weeks and finally bit the bullet
I ordered one 20 minutes before you posted the above, and have cancelled and re-ordered using the code.Use code Telegraph8MON brings it down to £812, i just ordered one![]()
oh nice, I was just about to order one! - good thing I checked this thread first.Use code Telegraph8MON brings it down to £812, i just ordered one![]()
Too true. You don't notice how bad VA is until you use OLED. Black crush/gamma shift/motion blur sucks.VA = pukego for it i have been lurking here for weeks and finally bit the bullet
and I got an extra £15 off by signing up for Dell Rewards and using the free 1,500 points they give you!
