Caporegime
- 9 Nov 2009
- Planet Earth
Founders Edition
Nvidia GeForce RTX 4070 Founders Edition review: return to normal | Club386
Nvidia takes command of mid-range gaming through efficiency rather than brute power.
NVIDIA GeForce RTX 4070 Founders Edition Review
NVIDIA's GeForce RTX 4070 launches today. In this review we're taking a look at the Founders Edition, which sells at the baseline MSRP of $600. NVIDIA's new FE is a beauty, and its dual-slot design is compact enough to fit into all cases. In terms of performance, the card can match RTX 3080...
Nvidia GeForce RTX 4070 FE im Test
Mit der GeForce RTX 4070 schickt Nvidia Ada Lovelace nun ab 659 Euro in die Händlerregale. ComputerBase testet die Founders Edition.
Nvidia Geforce RTX 4070 im XXL-Test: Der neue Effizienzmeister [Update]
Test der Geforce RTX 4070 und Vergleich mit Radeon RX 6800 XT: Welche Grafikkarte um 600 Euro macht das Rennen? Inklusive Effizienz und Preis-Leistung.
Nvidia GeForce RTX 4070 Review: Mainstream Ada Arrives
Roughly matching the RTX 3080 for $100 less and with DLSS 3.
Nvidia Geforce RTX 4070 – energieffektiv och kompakt - Test
Nvidia angriper övre mellanklasssegmentet med Geforce RTX 4070, det mest intressanta grafikkortet sedan RTX 4090.
Test : NVIDIA RTX 4070 Founders Edition - Overclocking.com
RTX 4070 : Notre test complet de la nouvelle carte graphique de chez NVIDIA, que nous allons tester dans sa version Founders Edition.
Nvidia GeForce RTX 4070 Founders Edition Review - OC3D
Introduction The improvement to the RTX range from when it first launched has been staggering. If the RTX 2000 series was the first edition of hardware ray tracing, and the 3000 series was the first time that you could realistically turn it on in anything, then the latest 4000 series has proven...
Will Ada be suitable for the masses? GeForce RTX 4070 Founders Edition 12 GB Review with 200 and 220 watt power limit plus OC | igor´sLAB
What do you do to raise awareness of a new product as a manufacturer? You simply split the launch of such a GeForce RTX 4070 12 GB and first release the cards that are also offered at the MSRP.
Group test
NVIDIA GeForce RTX 4070 Founders Edition & MSRP Model Review Ft. MSI, GALAX & PNY
NVIDIA GeForce RTX 4070 graphics cards are here and today, we will be testing out the MSRP models which retail at $599 US.
Hardware UnboxedYoutube reviews
$600 Mid-Range Is Here! GeForce RTX 4070 Review & Benchmarks
Thermal Grizzly: https://www.thermal-grizzly.com/produkte/522-cpu-contact-frame-for-12th-gen-intel-by-der8auerSupport us on Patreon: https://www.patreon.com/...
Gamersnexus
NVIDIA RTX 4070 Founders Edition GPU Review & Benchmarks
Sponsor: Thermal Grizzly Kryonaut thermal paste (on Amazon - https://geni.us/JMVNtOE ) & Hydronaut for water cooling (Amazon - https://geni.us/Fsray )The NVI...
Techtesters
RTX 4070 Review - 30 Games Tested, 1080p, 1440p & 4K
Testing the new Nvidia GeForce RTX 4070 in 30 games and 3 resolutions. Shopping: https://geni.us/RWf3z (affiliate)Sponsor: Seasonic Vertex PSUs are awesome! ...
Digital Foundry
Nvidia GeForce RTX 4070 Review: A Solid But Unspectacular 1440p Upgrade
Nvidia's Ada Lovelace roll-out continues, this time with the $599 RTX 4070, with a claimed RTX 3080-level of performance. Rich takes a look at 1440p performa...
LTT
I’m Dreading this Review – RTX 4070
Save 15% with code LinusTechTips at http://vessi.com/LinusTechTipsCheck out VideoCom for free at https://lmg.gg/VideoCom and use code LINUS for 50% off any p...
Paul's Hardware
Is $600 Too Much? RTX 4070 Review and Benchmarks
No-Frills RTX 4070 Review and Benchmarks: Is $600 Too Much?⇨ Sponsor: Micro Center! New Customer Exclusive - $25 Off ALL Processors: https://micro.center/qej...
Tech YES City
RTX 4070 12GB Review - The GPU WORTH $599?
NVidia is releasing their new RTX 4070 12GB at $599, and in today's review we break it down and compare it to a few key cards in the market, the RTX 3080 10G...
