RTX 4070 12GB, is it Worth it?
Status
Not open for further replies.
AMD has licensed RDNA as a uarch to Samsung:
I have a feeling they will continue to have some higher performance models for the desktop just for dev purposes IMHO. If not as mentioned above devs won't have compatible PC platforms to work on.
Jensons conditioning in full effect right here
:D
Still happy with 3080 perf here. Cyberpunk got uninstalled even after its 379th patch, flying round on broomsticks is bordering on a joke and what's the latest, a remake from 10 years ago in the last of us and then another remake that isn't even resident evil. Did I mention dead space remake. I'm holding out for 5000 series to play early access remake of a remake.
I am looking forward to Pong with path tracing.
You think AMD would at least like to have a go considering they would only need a card as fast as last gen for $50 cheaper to match what nvidia has put out.
While they have failed to get near nvidia at the high end you would expect a 20% performance increase for the same price at the mid range even in a bad year.
This is pure speculation from me but i suspect AMD are playing a much longer game, as are Nvidia. There's currently a limit to how small we can make transistors and how big a die is, there's a limit to how much performance we can get using traditional methods. Nvidia seems to be betting on AI while AMD are betting on connecting multiple chips together, both are trying to solve the same problem and i guess we'll find out who's right in the next 10+ years.
I was going to post something like that. But it would probably get reported for baiting or something again by the same lot :cry:
I doubt @CAT-THE-FIFTH was bothered my post earlier for example :D
I was wondering what that post might have been!
So true. Then Atomic Heart,which was meant to be this mega showcase of RT,then launched without RT and seems to run OK on most hardware!
Mine was around similar time. I got a good deal through a paper cutout from Curry's I think. Was £400 but had a AMD K6-2 400MHz which was better than a Pentium 400MHz at the time. It had 32MB of RAM and now I have 32GB :cry:
Not long after my upgrading obsesion began :D
Had a K6 2 350MHz at one point iirc, was great. Might even have been free as had a mate that used to give me his old CPUs when he upgraded :p
I can't believe it was nearly 20 years ago when we had unlockable dGPUs. Started with the ATI Radeon 9500 and the Nvidia Geforce 6 6800LE. Had one of the latter which unlocked to a 6800GT core config,and overclocked a bit higher(but the VRAM was a bit slower).
  • Like
Reactions: TNA
I unlocked my 9700 to a pro version via BIOS. I am not sure but I think may have also had to do something to the card too. I remember ******** myself doing it as it was the first time I had got a expensive graphics card.
The 9700 was like £170ish and the Pro version was like an extra £100 as I recall. I was so happy when it worked :cry:
Now it's all done for your convenience (as in you have to pay for it) :(
There were some 9500 non-PRO cards which were softmodded too,so could basically become a 9700 PRO,IIRC. The last two unlockable dGPUs I remember,were the HD6950 2GB unlocking to an HD6970 2GB,and some early reference RX480 4GB cards being 8GB cards.
Fun times. Now they want £1000+ for the unlocked card :cry:
I remember that.... It was my last actual agp that I ran for ages until I had issues with running youtube cause of some Intel protocol which was not present in the amd CPU's at the time. I actually bought the card from oc'ers & won the silicon lottery with the 9700 non pro version soft modded to the pro variant. I remember there was an app that let you mod the ati drivers to the pro version.. it was great while it lasted.✌️
Status
