It’ll give you a higher frequency and a lower perhaps a little lower power draw. Definitely worth messing with.
Not that experienced with AMD tuning. Will do some research and have a play this evening.It’ll give you a higher frequency and a lower perhaps a little lower power draw. Definitely worth messing with.
I'm using PBO tuner and just have it set up as per that video with a scheduled task, works a charm for me!Thanks for that.
Would you recommend pbo tuner or can I utilise the pbo tools in my bios? (Aorus Master x570).
Thanks for that.
Thanks for that.
With the latest beta bios for the X570 Aorus master (F37b) you can set the PBO offset in the bios rather than using PBOtunerThanks for that.
No that’s all there is to it.
Not at all, that's you.OK - think I've done it.
Am I missing anything?
I done exactly that, I'm glad I did as I now have a much cooler and better performing CPU than previously. The lows alone make such a difference to me.Really fighting the urge to get one of these CPU's. I can't see me doing a full upgrade any time soon and this would probably keep me going for quite a few years.
I swapped from a 5800x to a 5800x3D recently and it's been great. Lower power consumption and I think the noticeable piece (as others have said plenty of times) is the lack of frame drops. BF2042 feels mega smooth and on MW2/Warzone I previously would notice frame drops in high density areas, it's just non-existent on the new 3D CPU.Really fighting the urge to get one of these CPU's.
Now one thing to note, while you have PBO on there may be some instances where temps are slightly higher but you have to remember the chip will essentially run at max turbo under any load. So a 100% load should see a higher avg frequency than before. It's such an easy tweak on this chip and seems to work in a solid manner unlike the non X3D Ryzen CPU's.
That seems pretty normal to me. I'm also running -30 and if mine is just left on the desktop not doing anything I've noticed it drop to <100mhz at times with no problems. The core speed soon picks up once you start doing anything.Left my PC idle for a little this evening, noticed the min core speeds dropping as low as 224 MHz. Is that normal or does that indicate that -30 on the curve might be a little too aggressive? I haven't picked up on any instability.
Well i lost the fight.Really fighting the urge to get one of these CPU's.
