- 6 Feb 2010
It like drink company going "forget real fruit juices, check out our amazing artificially flavoured concentrated juice drinks- this is the future!"So basically less for more![]()
The 4080's have a £200 discount waiting to be priced in which will bring them to the £1000 that Nvidia wants to price them at. I think AMD will want to keep that £200 difference so that will remain, 7900XTX will be £800. And please don't think that Nvidia are being charitable here with the 4070 performance, it might be priced OK for the performance but not for the chip. It's a 60 class chip at more than 70 class pricing (they have raised the prices of 4070 class GPU's as well)Prices already are coming down, compared to what else is on the market the 4070 actually offers a good per frame cost, not good historically but still. Nvidia and AMD may want to keep prices, and profits, high however if people ain't buying what they're selling they have no choice but to lower prices.
Only 227mm2 of the 295mm2 AD104 is being used for the 4070 which works out at even less than the 3060 12gb which had 256mm2 out of the 276mm2 die in use so technically your getting an ADA card with a lower die spec than the 3060 12gb.The 4080's have a £200 discount waiting to be priced in which will bring them to the £1000 that Nvidia wants to price them at. I think AMD will want to keep that £200 difference so that will remain, 7900XTX will be £800. And please don't think that Nvidia are being charitable here with the 4070 performance, it might be priced OK for the performance but not for the chip. It's a 60 class chip at more than 70 class pricing (they have raised the prices of 4070 class GPU's as well)
From Turing even a GTX1650 super had a larger die area than a 4070 in use.
It’s so true.In terms of performance yes, but in terms of efficiency, the 40 series is genuinely considerably better than 30 series (and 20 series). A 4080 draws less power than a 3080 for example, it's 100W or more in power savings, runs quieter, runs cooler. Some will say you can undervolt a 3080, that's true, but then you lose a percentage of performance, even if it's 3-6fps, and you still don't get the low power draw of the 40 series.
So for me it would be knowing that now the 40 series and upcoming 50 series will be very efficient, and all it boils down to is the price, since the performance of all of them appear to be good for their class, just the pricing is all wrong which we know anyway.
The energy savings are exaggerated because other than the 4090 all the other cards are using the dies from a tier below their 3000 series counterparts.In terms of performance yes, but in terms of efficiency, the 40 series is genuinely considerably better than 30 series (and 20 series). A 4080 draws less power than a 3080 for example, it's 100W or more in power savings, runs quieter, runs cooler. Some will say you can undervolt a 3080, that's true, but then you lose a percentage of performance, even if it's 3-6fps, and you still don't get the low power draw of the 40 series.
The 4090 on the other hand uses a similar size die and has similar power consumption to a 3090 but the extra energy is going into performance which is why this card leads the 3090 by a much larger % than any of the other 40 series do their 3000 equivalents.
Energy in = heat out. That's usually my reason, that said I wouldn't just buy something because it was lower powered. I did run 7970 GHz Crossfire and that used to cook me! 300W max more or less now.I raised the energy consumption of cards once and was laughed at. Who cares about energy costs for a gpu? Yet now it seems to be the main reason people want a 4070. I kinda think they are just looking for a reason to get their two yearly NVIDIA fix.
Where are you getting that 40% figure from?The RTX4070 is basically 40% faster than an RTX3060TI
www.techspot.com
Why is it 44% on the 4070 review but 54% on the 3060 Ti page?TPU - actually works out about 44% at qHD. If you look through all their reviews,35% to 45% was about what you got in the other examples,but the price stayed between $330~$400 roughly.
Techspot/Hardware Unboxed are much less charitable:
Nvidia GeForce RTX 4070 Review
Nvidia's GeForce RTX 4070 release has been highly anticipated for its potential of bringing the newer generation to a new low price point and we're happy to...www.techspot.com
They arrive at 24% for their test suite,but TPU also includes older ones too.
Yet the RTX3060TI FE was £360~£370. It's a Turing V1 level of stagnation.
Its even worse when you compare it directly with an RTX3070,which is around 15% faster than an RTX3060TI.
Why is it 44% on the 4070 review but 154% relative performance on the 3060 Ti page?
Also your maths is off, the fake MSRP of the 3060 Ti was $399 so the 4070 is 50% more expensive not 60%.
The price is set in USD, using GBP isn't a good comparison due to currency fluctuations.The UK price was £369,and the RTX4070 price is £589. That is 60% so my maths is fine.
Lets face it how many people who just bought a 4070 for £600 would have done so had it been called a 4060 12gb.
I'm not excusing the rubbish prices, just pointing out that the GBP price is not a fair comparison. It's like saying the price increase is 89% because you bought them with Bitcoin, it's just not accurate because the price is set in USD.That is not my issue,and still excusing making for a 50% to 60% price hike,when you don't even get that level of performance increase? Sounds worse than Apple.
