But if the others weren't doing anything wrong, this won't affect them surely?
It will because AMD simply flips the set celling locked to 1.25v switch in their AGESA code, and that's it.
He's busy poking things and twirling dials. Youtube video will be incoming soon.
I think this will be fixed with a bios update tbh, surely AMD will be to blame though if it's multiple manufacturers.
I'm still fixed on my plan to get a non-X because of this page https://www.techpowerup.com/review/amd-ryzen-5-7600-non-x/20.html
L1 Cache | 64K (per core) | 64K (per core) |
L2 Cache | 1MB (per core) | 512K (per core) |
L3 Cache | 32MB (shared) | 32MB (shared) |
Might do that because surprise surprise OcUK declined my return request.@z10m it might be worth you contacting AMD, explain your concerns, be nice to them, maybe, just maybe they will help you out...
Why are you stressing ? You have a 3 year warranty on the CPU so if it degrades within that time you can get a brand new one.Might do that because surprise surprise OcUK declined my return request.
But if they weren't breaking that then what difference does it make?It will because AMD simply flips the set celling locked to 1.25v switch in their AGESA code, and that's it.
Yeah. Some people want it to be AMD, i think.
The usual suspects, though what goes on in here is mild compared to the utterly retarded rambling you see of some people on Facebook. Some of them can't even accept the 7800x3d is the fastest gaming cpu and its all a media conspiracy against intel. Makes some of the drivel you see on here actually seem rational.
so it was an issue with amd's agesa.
Yes, everything should be sorted in a month or so, so it might be prudent to wait.This whole situation is really putting me off my very near AMD / ASUS build. i am actaully considering going intel now, crazy times. will give it a month or two to see what happens but very glad i waited tbh
Well it can take time to show things. Like it's pretty apparent the x3d chips are more sensitive to voltage/heat so they just showed it up easier. Where as in the same situation the non-x3ds might have been fine with those voltages. GN mentioned that the shut down temperatures seem based on the non-x3d values too, so it seems like its part laziness too.Yes, everything should be sorted in a month or so, so it might be prudent to wait.
Something like this can happen to Intel or AMD and any board vendor when new platforms are introduced. The slightly disconcerting thing about this is that we're ~7 months into the release of AM5 motherboards and you would kind of hope that most of the gremlins would have been discovered and ironed out by now. There can also sometimes be the notion (maybe without good cause) that if there was an issue with this then what other yet to materialise issues could there be....
There is something to be said for getting well tried and tested platforms like AM4 or Z690.
The hardware that pumps the voltage out is controlled by software so if voltage is clamped in bios then its a permanent fix.. well it should be.I beg to differ: IMHO it is a hardware fault. That it can be worked around by software is only a temporary fix.
I hope you properly tested those memory overclock settings I gave you.Lovely just had a BSOD.
Soc set to 1.23 in bios and 1.25 reported in software.
Are you still running it at 6000 CL30? in that a manual tune or just EXPO?Lovely just had a BSOD.
They were working before but I’m back to XMP profile with lower Soc voltage. Seems 1.25v isn’t enough to for XMP be stable.I hope you properly tested those memory overclock settings I gave you.![]()
