Caporegime
- 9 Nov 2009
- Planet Earth
I don't agree as someone who has an RTX3060TI and knows plenty of people with an RX6600/RX6600XT. Many game at qHD because qHD displays are dirt cheap. I game at qHD too.I think the thing to remember about 1080p cards, is that 8GB N33 GPUs can already comfortably deliver 60 FPS minimums, as these cards can run Cyberpunk 2077 (impressive in itself for a low end mobile GPU)...
So, there's little reason to increase the spec, for what is supposed to be the lowest tier GPU die.
The Navi33 die was (predominantly) intended for mobile devices, as discussed here, back in August 2022:
It's 6nm which makes it cheaper and easier to mass produce.
I also have used the RTX3060TI,RX5600XT,RX5700XT and RX6600XT myself(only have the RTX3060TI and RX5600XT now).8GB is starting to be an issue,even in some games at 1080p. It definitely is already an issue if you mod games @KompuKare has also mentioned this.
Navi 23 was made for mobile too like Navi 24.But AMD is going to use Navi 33 against the RTX4060. The RTX4070 was roughly RTX3080 level performance. The RTX4060TI is probably around RTX3070 to RTX3070TI level performance,and the RTX4060 is probably between RTX3060TI to RTX3070 level performance.
The reality is if AMD intends to sell the RX7600XT at around £300ish,it will be fighting against an RTX4060 with similar rasterised performance,much better RT performance and better "software" features.
So it does need 12GB to 16GB to differentiate itself,and more importantly that VRAM will help over time.
If they want to have it only as an 8GB card it needs to be under £300. If not you can get an RX6700XT 12GB for under £350 right now.
Edit!
Also HUB showed the 8GB cards in Hogwarts Legacy have severe texture streaming problems.
So those FPS numbers don't take into account that 8GB cards seem to be loading worse quality textures.
So for a few extra USD AMD could add that extra VRAM,and end up showing up the RTX4060 series for the cash grabs they are. Imagine if an RTX4060TI starts losing to a "slower" RX7600XT 16GB? OTH,if they want to price high with low specs,they will end up making the RTX4060 look better.
It's not Rocket Science.
