- 23 Dec 2022
- London
Some of Steves theories do seem to be a bit speculative. Im not denying there is any issues.
I think the concern is with these things if channels do something and it has a lot of success you can overdo or overegg it a bit - it's only natural to try to chase the numbers a bit although GN generally is one of the better ones. Has anyone on this forum found anything at all?Some of Steves theories do seem to be a bit speculative. Im not denying there is any issues.
I've been doing this a long time. I've never seen/heard of a motherboard warranty being refused due to installing a beta BIOS. The most that'll be done during a RMA is a quick visual check, to match the serial number, check no obvious physical user damage.It's actually worse because if you install a beta BIOS and your motherboard dies, it's not covered under warranty. Check their disclaimers on every website (coz I cba)
So, as far as I'm concerned, as long as there are only beta BIOS available they still haven't actually fixed the problem.
I'd recommend all Ryzen 7000 owners to inspect their CPU's contact pads and motherboard socket pins, check this video to see the angle/lightning you need to spot the visible burn marks (will likely be much less noticeable if your CPU is damaged but still working)
And if there’s burn marks, what then?
Send CPU back to Overclockers for refund or replacement?
Maybe all LGA based systems. Cleaning the pads once in while will prolong the service life, especially on a CPU that pulls a lot of power and produces a lot of heat.
Take Gigabyte for instance, it takes them ages to move their latest bioses out of beta status, like they gave up on them, and when I say ages, I mean months and months, it had to be at least 9 months before they moved a bios for my X570S master out of beta to final, and when they did, if I remember correctly the beta for AGESA V2 1.2.0.7 came out 2 weeks later, thats only recently been moved to final and a new beta for AGESA V2 1.2.0.8 is now available, now if I dont flash those beta's, i'll of been missing out on the latest fixes etc for god knows how long, so I know the disclaimers may say a beta isnt covered, but I really dont think they could deny you a warranty repair or replacement because you board has a beta bios on it, I mean hell, they put them on the site for the public to download and flash.It's actually worse because if you install a beta BIOS and your motherboard dies, it's not covered under warranty. Check their disclaimers on every website (coz I cba)
If there's burn marks it's already dead
You will learn absolutely nothing from looking at your cpu.
Clean them of what
They are out of a packet straight into a socket. The only dirt on the pads is if you start "cleaning" them.
Man, this x such a big number...the amount of posts advising to check CPUs for burn marks on otherwise fully functioning systems.If there's burn marks it's already dead
Clean them of what
Dude! At this point I'm just so skeptical about this whole fiasco that comments like "Check your CPU for burn marks" are people just trolling.Man, this x such a big number...the amount of posts advising to check CPUs for burn marks on otherwise fully functioning systems.
Have people even seen what 5nm looks like? No they haven't because no-one has or ever will be able to with the naked eye. How hot does it need to be to burn a pcb or scorch metal? If you can see physical damage the CPU would be so far beyond dead. These suggestions are ridiculous.
What are you doing to your CPUs before installing them, using them a fidget spinners or something.Mostly oxidation and very fine dust. I’ve been surprised with the amount of finger grease I’ve found on pads.
Come again? You got any proof of LGA based systems having this issue as a platform deficiency?
Or maybe = I’ll make up a wider issue to defend my team.
Google LGA burnt CPU pins?
As expected lots of images of burnt pads on google. Have a few faulty Intel servers currently sitting on healing benches. Can open and provide images? 100% will find scorch marks, discolouration and charred pins sockets.
Yeah let's see them along with info. Maybe my google is broken.
I equally struggled to find a scenario where the manufacturer and partners had to run around and mitigate the issue. Maybe you can help me find that also.
Yup, your google must be broken, either that you you just simply couldnt be bothered to look, came straight up for me:Yeah let's see them along with info. Maybe my google is broken.
