The AD103 based 4070 series is going to have 16GB so problem solved. Already confirmed by kopite7kimi.
Confirmed?
That tweet just says "can"
That would also seem like a bizarre release, especially anytime soon.
Confirmed?
He has leaked a lot of Nvidia releases. Remember everyone doubting the Super releases? He leaked them IIRC.Yeah that Twitter guy should be ignored imo.
Or Nvidia emergency rejigging the GTX200 series pricing and releasing the GTX260 216 and GTX275? Done at quite short notice.
If sales are not good, then it's most likely Nvidia will let the current range run down:
Nvidia reportedly cutting supply on slow selling RTX 4070 GPU
Is the worm finally turning on Nvidia's premium pricing strategy?www.pcgamer.com
Already rumours of an RTX4070 production cut. In a couple of months Nvidia releases the RTX4070 Super 16GB and RTX4060 Super 16GB.
Nvidia had no problems screwing over it's earlier customers before.
Nvidia within months has made moves like they did with the GTX200 series. We already are half way through the year now.I am not saying a refresh with an AD103 16gb 4070 isn't possible. I just doubt it is imminent (if it happens, probably end of this year/start of next)
He said AD103. AD103 has a 256 bit bus.I don't get it, why wouldn't a 4070 Super variant be based on AD104?
Is it related to the memory bus configuration of AD104?
They'd have to cut down AD103 a lot if the rumour is true.
Are 'Super' cards even a thing still? they didn't bother with them for the last gen.
Do you honestly think they were going to make an RTX4060TI 16GB? All these games using a lot of VRAM happened in the last month or two.
Nvidia hates bad PR.Now it's clear games are pushing VRAM, they will do something to manage it.I have no idea. Probably. They made a 12gb 3060 which had more vram than the 3060ti, 3070 and 3080.
They didn't do that for Turing. Releasing new "better value" models means reviews have to be done again. Nvidia gets praise for listening to their customers. The older negative ones of the "old legacy models" are now history. It's all about optics.I think it would be better to just cut the price of the 4070 TI
No need for Super model then.
AD104 (4070Ti) with 7680 shaders already is a fully enabled core - there is nothing left to "switch on" for a Super variant.
Equally cutting down an AD103 probably isn't a great option - aside from the cost of using such a big core for a lower product, in order to keep 16GB of RAM, you can't cut the memory bus, which then means that cutting the core configs etc leads to quite an unbalanced product, possible outside of the range that it's designed to work
Hmm. with the RTX 2000 series, the 2080 Super card was slower than the respective TI model.
So, I was thinking a cut down 4070 TI could be the Super variant.
Nvidia emergency edition. Not only are they realising negative customer perception but also the fact more games are using VRAM and 8GB isn't enough. The RTX3060 can outperform the RTX3070.
Might also be because AMD might be releasing an RX7700XT 12GB too at the RTX4060TI price.
Also:
He is a reliable leaker.
That means a 16GB 70 series card.
But what if you just invested in a 4070?...
Because the AD104 is rubbish and people who pay £600+ for GPUs expect better?.I don't get it, why wouldn't a 4070 Super variant be based on AD104?
I'll take a guess and say they will market a 16GB 4060ti so much above a 8GB model that one might as well pay the extra for a 4070. You want VRAM... its not going to be free.
So not only will these be overpriced these cards will last abit longer than a 8GB card but will suffer esp at higher res due to 128 bit memory bus / bandwidth / grunt compared to cards that could properly use it.
If that RTX4060TI is real it's about optics. So even if it leads to an odd looking stack,they will try and rejig it now.
But TBF,the AD103 is really the GA104 replacement,ie, similar die size and memory bus width. So the upsell is huge.
Everyone was wondering why there wasn't an SKU made from a salvaged AD103? Technically that should have been the RTX4070TI.
There is plenty of scope to release a slightly faster RTX4070TI,for similar money with a wider memory bus. The RTX2080 was only 7% faster, according to TPU, when compared to the RTX2070 Super.
The RTX2070 Super essentially replaced the RTX2080:
NVIDIA GeForce RTX 2070 Super Founders Edition Review
NVIDIA gave the GeForce RTX 20-series a midlife refresh with the new "Super" brand extension in the wake of AMD's upcoming Radeon Navi 7nm GPU. The RTX 2070 is based on the RTX 2080, which means SLI support and more shaders compared to the the original RTX 2070.www.techpowerup.com
It was essentially 70% of the price of the RTX2080 and the RTX2080 was only 7% faster.
The RTX4080 is 20% faster than an RTX4070TI at qHD and the latter is 2/3 the price. So if you split the difference,and move to 16GB at the same RRP as the RTX4070TI that is your RTX4070 Super. Nvidia sells it at RTX4080 level performance at 2/3 the price.
Then push down the current RTX4070 series in price. Might also see an RTX4060 Super in the future too. Could be a slightly slower RTX4070 12GB.
This was what the RTX2060 Super was to the RTX2070! So you could see essentially:
1.)RTX4070 Super(AD103 based)
2.)RTX4070TI(AD104 based)
3.)RTX4060 Super(AD104 based)
The RTX4070 Super and RTX4070TI will be close in performance,but Nvidia gets to upsell it still because of more VRAM.
The difference between the RTX4060 Super and RTX4070TI will be greater than 20% so Nvidia gets to upsell more performance.
They'll have to do something because most people simply won't pay the higher asking prices for cards which have a poorer generational uplift compared to the past, £1200 for a 4080 which is only 17% faster than last gen while for the same price previous you got a 3080ti which was 40% faster than previous gen. The 4070ti is 7% slower than last gen for £800 yet the 3080 was 25% faster for £650, so your basically paying £150 more for 30% less performance than you got previously, thats a big swing and its the same for the 4070, +£100 more for 30% less performance.AD104 (4070Ti) with 7680 shaders already is a fully enabled core - there is nothing left to "switch on" for a Super variant.
The 2070 super came out 9 months after the 2070/10 after the 2080.
Again, i'm not saying there will not be a refresh or a 4070 super because there is always something new around the corner.
I just doubt it will be in the next couple of months....The 4070 came out less than a month ago!
