ah well thats news to me, i assumed not as it wasnt mentioned on the nvidia store page but i can see it is in the basketDiablo comes with all 4000 series FE cards.
Surprised to see the 4090 still in stock, the last drop they lasted around 12 hours, this drop it's been 24 hours so far.
If the rumoured die size is correct at 190 mm² and TSMC's 5nm wafer costs are around the rumoured $17k anyone want to do the maths for how much Nvidia are paying for each 4060Ti die?
I would but my maths skills are awful.
Charging £1,579 for a GPU will do that.Surprised to see the 4090 still in stock, the last drop they lasted around 12 hours, this drop it's been 24 hours so far.
Cheaper cards always have better cost per frame. I'm sure the 3060ti has much better cost per frame than the 7900xtCharging £1,579 for a GPU will do that.
Just to clear something up, the 4090 is not good value.
It costs around £9.40 per frame at 1440p (based on 1% low of 168, MSRP price).
The RX 7900 XT costs around £5.76 per frame at 1440p (based on 1% low of 130, price £750).
At 4K, cost per frame is £9.61 for the RX 7900 XT and £13.73 for the 4090.
If they drop the price of the RX 7900 XT further (e.g £700), the value of the 4090 will look even less favourable.
It's not even that really though.Also 1440p is not where you should be testing a 4090. The cpu bottleneck will be nuts.
Is it? You can get a 3060ti from EU for 370 euros. If the 7900xt is double the performance it needs to costs 740 to be of equal value.I would not be so sure about that. It is about double the price, but also double the performance, so will have very similar cost per frame...
Sapphire Radeon RX 7900 XT Pulse Review
Sapphire's Radeon RX 7900 XT Pulse is one of the more affordable RX 7900 XT custom designs out there. For $860 you get impressive 4K gaming performance and a triple-slot, triple-fan thermal solution that achieves amazing noise levels with good temperatures. Overclocking worked very well, too.www.techpowerup.com
The 4090 is twice the price of a 7900 XT but only 30% faster at 1440 and 44% faster at 4k (so maybe on average 37/38% faster).
The 4090 is poor value.
And that's insanely good value actually. A 1 to 2 price to performance ratio at the high end is pretty great. If you do the same math the 7800x 3d isn't a good value cause the 7700x is much cheaper.It's not even that really though.
The gap in 1% lows is about 35 FPS between the RTX 4090 and RX 7900 XT.
So the price is more than 2x as much, but you get about ~47% higher framerate.
As I've said before, performance doesn't scale linearly with price. A 44% performance gap is actually insanely big when we are talking about high end products.
I was using EU prices, cheapest xt is 849 euros, while cheapest 60ti is 370.?
The 7900 XT is £750 here. Cheapest 3060Ti's are still £360, so yes the 7900 XT is pretty much bang on twice the money (ok £30 more than double..), but for twice the performance.
I was responding to your point about the 3060ti having "much better" cost per frame than the 7900 XT which is 100% not true. They are almost identical.
Since when?A 1 to 2 price to performance ratio at the high end is pretty great.
