A real toy at last - as said either sit on floor and get someone to hand you the logs or on a good strong bench but you still have to bend down for each log.
I have mine in doorway of shed on the floor and kneel down -throw a load of logs in and split those -they shoot out of door - repeat repeat etc.
Also it might pay you to get some blocks of hard wood - if you have short log put that on behind log so you don't have to let arm go too far along before contact with log. Also you will find the arm runs out of push at end so a spare piece comes in handy behind log.
It looks same as mine so don't forget to undo the pressure screw before you start. mine is a plastic knob with two wings on it. Close it after use.
Hat-gloves-glasses-ear defenders-plaster-bandages-antiseptic-emergence number - Hope it goes well.
Plus steel toecap boots
