I will have a look later m8 and drop you a message thanksAre you using Fidelity CAS? Any other settings I should know?
I will test later and let you know
Yup. I created a little table (logical core numbers) for CO testing to make things a bit easier.Y-Cruncher users, a simple question.
I think its obvious, but i'll check anyway.
On a 7800X3d - If the stabilty test fails on ' logical core 12 ' - am i correct in assuming that is core 6 ( if 1-8 ) / core 5 ( if 0-7 ) - same core basically. Each core being 2 threaded.
Tuning Curve Optimiser, so want to double check i'm reducing the correct core.
Thx
Nice one - Thx MattYup. I created a little table (logical core numbers) for CO testing to make things a bit easier.
core 0 = 0/1
core 1 = 2/3
core 2 = 4/5
core 3 = 6/7
core 4 = 8/9
core 5 = 10/11
core 6 = 12/13
core 7 = 14/15
core 8 = 16/17
core 9 = 18/19
core 10 = 20/21
core 11 = 22/23
core 12 = 24/25
core 13 = 26/27
core 14 = 28/29
core 15 = 30/31
I done the exact thing on my phone. It comes in handy.Yup. I created a little table (logical core numbers) for CO testing to make things a bit easier.
core 0 = 0/1
core 1 = 2/3
core 2 = 4/5
core 3 = 6/7
core 4 = 8/9
core 5 = 10/11
core 6 = 12/13
core 7 = 14/15
core 8 = 16/17
core 9 = 18/19
core 10 = 20/21
core 11 = 22/23
core 12 = 24/25
core 13 = 26/27
core 14 = 28/29
core 15 = 30/31
It took me weeks to get things properly dialled in, but it’s a good feeling when you know it’s done and you no longer have to worry about any stability issues (if you did it properly). To clarify, when I say weeks, I mean curve optimiser hand tuned each core for 100% stability, whilst using as much negative offset as possible.
I’ll have to check and get back to you, but it varies depending on what profile I’m using. I have my tuned profile with clocked memory etc, then I have a low power profile running memory at 5200Mhz and other voltages and power limits lowered.Hey Matt, what is your total package power at complete idle, as reported by HWinfo? I'm curious to see the difference between stock and a fully tuned 7950x3d.
Cheers
I've got both rigs booting off a 1TB 990pro, can't tell a difference in windows11.What's 3d like in windows 11, is it as responsive as a raptor lake system, could you tell the difference in a blind test.
Cheers
36W with my overclocked profile, 6200C26 @1.59v VDD and VDDQ 1.41v.Cheers. I'm curious as I may make the time to do this properly, though only if it's a ~10w+ saving at idle, else I won't bother. At full gaming load, it sips power anyway. Hilarious seeing Diablo4 running at 50W for example![]()
Thanks. Will compare with mine later
Sounds about right. I think with my low power profile it drops 10W or so but I'd have to check.I get 33w stock, with EXPO 6000Mhz C30, cores on stock voltage. I thought undervolting with curve optimizer would have some effect on idle package power wattage at least? Or is it only at full load that power consumption is reduced?
Curve Optimiser @ - 31 all cores / c30 6000mt/s. Been idling/ light loads all day with no issues aswell.
That’s a very good luck getting -31. My two best cores on CCD1 can’t get passed -25 but other 6 on -30.Still more in the tank i think.
Wooow I never said that I don't even know what that means heheThat’s a very good luck getting -31. My two best cores on CCD1 can’t get passed -25 but other 6 on -30.
Is it ok to go past -30? I thought -30 was max. If so I can push a bit more maybe.
and me just plugged it in and game.
rocks so hard btw
