- 19 May 2010
- Cheltenham
Even better. Chuck another handful into the coffin for extra measure.
Plot twist - it was hired by Dignitas for people wanting to be buried near the Titanic.
I think everyone assumes the Titan is some highly advanced piece of kit, when the reality is it's a floating tube with a window near a crude makeshift bog...There is no door, the tube is bolted together after the people get in.
Imagine being stuck in that *******, jesus ChristI think everyone assumes the Titan is some highly advanced piece of kit, when the reality is it's a floating tube with a window near a crude makeshift bog...
Don't personally see the issue with the xbox type controller, these things have had a lot. Of money spent on the design and they are tough as nails. I do an issue with a wireless. Connection however!
It can't be as bad as us arm chair experts think. How many successful trips has it made?
I do hope we find answers to this and some thing is recovered
3How many successful trips has it made?
Something to do with like how they say its bad to wear tight shoes on a plane?
How are you going to noticeably vary the length of a noise (eg a bang) caused by a striking impact?! You aren't, so you use a pattern of different pauses to indicate the same thing.
Hell to the noImagine being stuck in that *******, jesus Christ
I get heart palpitations just looking at the 3 images of the sub. What an horrendous titanium coffin.
Any naval radio operator who cannot pick up a pattern of repeated noises is not likely to be a naval radio operator.Its why I deleted my posts because even though the examples on the web say otherwise its somewhat distracting yes.
Seeing as views differ in regards when you cannot do it properly. Was quite interesting actually to google the response to the same question.
Eg https://www.quora.com/How-do-you-send-Morse-code-just-by-tapping
One for example saying if you need to do SOS via simple tapping you would do the S with the three very quick taps and the O with three quick but spaced longer
Another saying you do a tap for the S dots but more of a scrape for the O part
Another saying they were taught to double tap for the longer ones if you cannot create a long single tap (apparently this goes well back)
It all relies of course of the skill of someone picking it up.
I was taught to morse with a torch as I did some long distance walking and that was always 111 222 111 (where 1 = short flash, 2= longer flash)
Like in this vid here at 2:51, exactly how I was trained to SOS on a torch (which is supposed to be universal of all forms)
Teen Tech: Morse Code with Flashlight
Learn how to use Morse Code! This is a useful and fun way to learn how to communicate if the power goes out or if you have poor phone reception.Morse Code Tr...www.youtube.com
It just makes you wonder what else could have been improvised, going that depth looks like it's just as difficult going into space you can't be messing about with anything
A Sealed small metal container certainly isnt a good place to be if you have smelly feet !Looking at the internal pics of Titan just posted here, I'm guessing it's due to the proximity of the passengers and pilot, so they don't kick each other with boots and shoes.
Is that Linux Mint OS?I think everyone assumes the Titan is some highly advanced piece of kit, when the reality is it's a floating tube with a window near a crude makeshift bog...
Frankly it should be classed as a miracle its achieved a couple successful runs.I think everyone assumes the Titan is some highly advanced piece of kit, when the reality is it's a floating tube with a window near a crude makeshift bog...
