- 25 Nov 2005
what is the seabed like around the Titanic ? does it get deeper or is it pretty flat ?
You can turn on depth contours to see how deep it gets
It's good to think about other things in times of potential distress
Grim thought, but would the sub passengers consider reducing number of those breathing air, to prolong air left so some might be rescued ?
Who knows what they would be doing if stuck and some end up losing it , just brings shivers thinking about it
Just hope they at least find it otherwise many questions will remain unanswered
Have they thought about nuking the Titanic so nobody ever tries this again?
What about Greek gods?If you're superstitious, I read an interesting point that sailors believe it unlucky to name a vessel after a ship that has previously sunk.
No problem an empty bottle, a couple of sheets of newspaper, a black bin bag and it will be more structurally sound than the sub itself.
Expert on BBC saying the best thing for them to do is relax, maybe take some sleeping medicine, ffs.
Did the BBC listen to a different press conference to the one I heard?
3. It's OK to use components not certified for something if you take on the validation, and there have been test dives at depth, I'm sure I heard in the documents they filed to get approval for the trip it had also been in a pressure chamber, and they do say the design intent is 2.25x safety margin (odd since 2.5x is more industry standard IME) which is not too bad.
Would it be cold onboard?
It's the only way to be sure.Have they thought about nuking the Titanic so nobody ever tries this again?
