Probably. However they were likely not wanting to speculate on it. It seems fairly clear the banging is happening but whether it’s the sub or not is not clear.Is this the same thirty minute banging that the coast guard said they know nothing about in the press conference yesterday but which the media seem to be still reporting?
Theres no way its the sub
If you were down there you would be. Banging constantly wouldn’t you and not at 30 minute intervals
I think personally, if I was a billionaire I'd be enjoying a life of luxury, not finding any possible way to end it early. So many more things that are amazing to do that don't involve you going to the bottom of the ocean in a bean can.
Always felt it a bit morbid to visit the Titanic in any case. We know what it looks like and treating it as a tourist attraction is just sad.
Agreed. My bet is that it was an implosion. A complete power loss would not have stopped it surfacing. Had it got caught on something, I'm sure they would have made more noise.
At over two tons per square inch, water is explosive. Death would have been instant. In fact, I really can't think of anything more instant. When you think that most pile drivers probably operate at less pressure than that....
WordIf you were down there you would be. Banging constantly wouldn’t you
Someone mentioned earlier in this thread that banging on the hour and half passed the hour is done so you make a repeating pattern so it's known not to be something else. Which ultimately can help with locating it as the know they can ignore sounds at other times and focus all sonar on triangulating the hour/half passed signals.
However the 30 minute interval seems to be something made up* as, AFAIK, it's not been confirmed by anyone involved with the search. *though if it is the done thing, I wonder if someone in the press found the details and in the rush to get updates out conflated the what should happen with what is happening.
It would be better find they died instantly.Just talking about this now. We were wondering whether it would be better not to find them now. Rather live in hope they didn't suffer or find the vessel intact and know they spent their last days in terror.
Horrible for all involved.![]()
When installed, FADOSS "is welded to the deck due to the structural requirements for the lift to support the weight of whatever object we're pulling off the bottom," they continued. "Our estimate is approximately 24 hours [of] around-the-clock operation to weld it and secure it to the deck of the vessel prior to getting underway."
Phoenix used the U.S. Navy’s 20,000 fsw rated CURV 21 ROV to inspect the wreckage and attach rigging to the aircraft. Next, a 22,000 ft long, 2-inch diameter Kevlar recovery line was lowered to the seabed and the ROV was used to connect the recovery line to the wreckage. The U.S. Navy’s FADOSS was then used to pull up on the Kevlar line, hoisting the MH-60 helicopter from the seafloor to the surface. After nearly 4 hours
i have been called worse,You are Gerry Anderson and I claim my ten pounds![]()
not if somone was there to explain why that is a poor use of energy / O2.....Theres no way its the sub
There’s no confirmation of the banging at 30 min intervals. The media are reporting on it but no official word.
if it isnt possible then fair enough. i just assumed there would be high pressure devices capable of it used for this sort of thing, but I guess not.How are you going to use an inflatable mat with the pressures down there?
You'd think would have multiple methods to send signal if one didn't work? Or technology hasn't advanced enough ? in that case more reason not to do ittill more advances are found
