- 27 Jan 2022
- UK
Outside of game pass, you can get the same games cheaper on a series x as well
The 4090 is twice as fast as a 4070 though and 70% faster than a 4070ti so hard to consider those cards high end.Ultimately I think the real issue is all down to Nvidia and their pricing and product stack vs. what we consider to be entry/mid/high-end. 70 series was never mid tier, it was always high tier - and it absolutely shouldn't be considered mid-tier at 589 quid
Tier A is the 4090, you're calling the 4080 and XTX and also the XT midrange when they are in Tier B in GPU Hierarchy thread- not sure why you feel the need to re-write all the gpu names to help you make sense of the current market.The 4090 is twice as fast as a 4070 though and 70% faster than a 4070ti so hard to consider those cards high end.
I think you're from the States?- I see a 7900xt for $779 is that including taxes? If so why does the Pound and Euro match the US price but really we pay a lot more?Emulation makers tell people to stay away from the 4060 and 4060ti, get the 3060ti instead or face a serious downgrade in emulation performance.
The memory system on the 4060 series cards is severely hurting emulation performance
Nintendo Switch emulation team at YUZU calls NVIDIA's GeForce RTX 4060 Ti a 'serious downgrade'
With its downgraded 128-bit memory bus, the Nintendo Switch emulation team at YUZU has shared its thoughts on the new GeForce RTX 4060 Ti.www.tweaktown.com
Comparing fake frames with no fake frames. Dumb.
Because B tier is generation behind A tier in performance.Tier A is the 4090, you're calling the 4080 and XTX and also the XT midrange when they are in Tier B in GPU Hierarchy thread- not sure why you feel the need to re-write all the gpu names to help you make sense of the current market.
Can you build a console that destroys a 500 pounds PC? Nope. Silly comparison.You're wasting your time. He's deluded. It's been covered loads of times that you can't really build a console destroying game for under £650
Just look at almost every digital foundry game analysis lately and you will see PC games are plagued with issues and stutter that cancels out a lot of their advantage anyway.
Outperforming in compute workloads, AFAIK that's pretty different than gaming.Nvidia RTX 4060 benchmark shows it outperforming the RTX 3060 by up to 17%
Nvidia RTX 4060 benchmark shows it outperforming the RTX 3060 by up to 17% - KitGuru
While originally planned to launch in July, the RTX 4060 will now be arriving before the end of Junewww.kitguru.net
4090 is a Titan class card so not one for the enthusiast gamer.Because B tier is generation behind A tier in performance.
Its not a Titan class, the die is more cut down than any of the 80ti cards. A titan uses the full die.4090 is a Titan class card so not one for the enthusiast gamer.
Tier B is enthusiast category.
You’ve got it all wrong mate.
You won’t get the magic price to performance you are expecting. Keep that 3080 going for another 5 years maybe? (Or get a 5060ti? cost potentially £600)
That's because the Ada die is much much much bigger than anything before it, in terms of transistor count. Giving you 50% of 10k euros is not the same as give you 50% of a million, right?Its not a Titan class, the die is more cut down than any of the 80ti cards. A titan uses the full die.
Notice where the 4080 sits as well in with the other 70 class cards while the 4070/ti sits in amongst the 60 classes.
Christ, that chart really puts things into context with how much Nvidia are trying to screw everyone this generation.Its not a Titan class, the die is more cut down than any of the 80ti cards. A titan uses the full die.
No matter what patterns this OP has found it doesn’t change the fact Nvidia is happy to call the 4080 an 80 class card and they’re not going to re-write that for you or any gamer.Its not a Titan class, the die is more cut down than any of the 80ti cards. A titan uses the full die.
Transistor count is meaningless in terms of size, cost, performance and pretty much everything other than 'look how good our fabrication process is'.That's because the Ada die is much much much bigger than anything before it, in terms of transistor count. Giving you 50% of 10k euros is not the same as give you 50% of a million, right?
Table created to visualise the BS
Model Die CUDA
CoresMemory Bus
(bits)Bandwidth
(GB/s)VRAM
(GB)TDP
(W)Price Mobile 4050 Laptop AD107 2560 96 6 35-115 Mobile 4060 Laptop AD107 3072 128 8 35-115 Mobile Workstation RTX 2000 ADA AD107 3072 128 8 35-140 Desktop 4060 AD107 3072 128 272 8 115 $299 Desktop 4060Ti AD106 4352 128 288 8/16 160 $399/$499 Mobile 4070 Laptop AD106 4608 128 8 35-115 Mobile Workstation RTX 3000 ADA AD106 4608 128 256 8 35-140 Theoretical AD106 Max AD106 4608 128 Fake/Leak 4060 Super 5120 192 432 12 200 $399 Mobile Workstation RTX 3500 ADA AD104 5120 192 432 12 60-140 Desktop 4070 AD104 5888 192 504.2 12 200 $599 Workstation RTX 4000 SFF ADA AD104 6144 160 320 20 70 Mobile 4080 Laptop AD104 7424 192 12 80-150 Mobile Workstation RTX 4000 ADA AD104 7424 192 432 12 80-175 Desktop 4070 Ti AD104 7680 192 504.2 12 285 $799 Datacenter L4 AD104 7680 192 504.2 24 285 Theoretical AD104 Max AD104 7680 192 Fake/Leak 4070 Super 8192 256 672 16 280 $699 Mobile 4090 Laptop AD103 9728 256 16 80-150 Mobile Workstation RTX 5000 ADA AD103 9728 256 16 80-175 Desktop 4080 AD103 9728 256 761.8 16 320 $1199 Theoretical AD103 Max AD103 10240 256 Fake/Leak 4080 Super 13312 320 840 20 350 $1199 Desktop 4090 AD102 16384 384 1008 24 450 $1599 Datacenter L40 AD102 18176 384 864 24/48 300 $8000 Workstation RTX 6000 ADA AD102 18176 384 960 48 300 $6800 Theoretical AD102 Max AD102 18432384 Fake/Leak 4090 Super 18432384 1152 24 450 $1999
So it costs more to make a true old fashioned 80 class gpu- hence it’s not economically achievable for Nvidia which explains why comparing to past gen die sizes and scrutinising value for money might be inaccurate?The yields on the full die part are terrible - you only have to look at the L40 Datacenter and RTX 6000 ADA Workstation parts to see this (and these are intended for the current cutting edge AI market, that wants every bit of power that they can get) - Even those aren't using the "full" die (although they are a lot nearer).
Look at the price premium for such parts
