The 7800X3D would probably get a bit more than 15K as it could boost more. The 7950X at 90W is much more power limited. Think they get 18.1K at full power so probably don’t drop much at 105W.Your 7950x is damn impressive. The 7800x 3d on the other hand, ouch. Highly inefficient.
You have a 7800x 3d?Regarding power use.
6 watts more Vs 13700K, that does not bother me. Coming from a raptor lake 13600k, I much prefer AM5. LGA 1700 is a eol after the needles refresh coming this year, who wants to invest in a power hungry, hot, end of the line setup.
I agree with you. Even if we disregard this enormous difference in power consumption during gaming, Intel's platform is dead. It's simply hard to find an argument in favor of Intel.Regarding power use.
We all agree that the 12900k is inefficient. When it beats the 7800x 3d, easily might I add, doesn't that by necessity make the 7800x 3d also inefficient?Every time.
Out of the box definitely yes, but not for me when tuned. I would say it you look at the first chart, from Watch Dog legions down the 13700K was faster and definitely the smoother gaming experience. I sometimes got a bit of a stutter with the 7800X3D which I never did with 13700K. I don't have the high power usage the HUB seem to have and my 13700K runs the same temps as my 9700K so easily cooled by my AFII 420mm.Yeah, for gaming with a high end GPU and it’s 7800X3D or you wasted money.
Was that on games with DLSS 3? It's a known issue, witcher , cyberpunk, diablo 4 have excessive stuttering on zen 4 when you enable FG. Nvidia is on it I think, they might have fixed it already, dunno.I sometimes got a bit of a stutter with the 7800X3D
I'm probably an edge case and for the vast majority of people who don't want to spend hours fiddling with settings and just want to plug and play and only game then the 7800X3D is an easy choice.
No DLSS 3, this was playing Spider-man Remastered, Jedi Fallen Order/Survivor, Far Cry 6, CP2077 and a few others.Was that on games with DLSS 3? It's a known issue, witcher , cyberpunk, diablo 4 have excessive stuttering on zen 4 when you enable FG. Nvidia is on it I think, they might have fixed it already, dunno.
That is while I'm gaming. Remember I have HT off which also brings the heat output down. So having both of them I can assure you they are pretty much the same.I’m pretty sure the heat output of your 13700 is a lot more than 9700K. The 9700K was one of the last Intel chips with sane levels of power use.
Ah okay, well Spiderman and cyberpunk needs lots of cores, your ecores work overtime there. The 3d doesn't have them so, makes sense.No DLSS 3, this was playing Spider-man Remastered, Jedi Fallen Order/Survivor, Far Cry 6, CP2077 and a few others.
Exactly the opposite for gaming!But then you drop a lot of performance.
Yeap, HT off ecores on is the best for gaming. You can't do that on the 3d cause it will choke on just 8 cores without HT. That's why im eagerly waiting for a single ccd 12core 3d zen. That's going to be nutty.Exactly the opposite for gaming!![]()
