They generally don't comment on unreleased features/improvements.Have they made any sounds about improving/expanding it?
I've got a USG which seems to of failed early today.
No lights/internet connection except a blinking green light next to the console port.
A few videos show a psu problem but I have a green light on the brick .. I've changed the plug to the brick but no fix.
If this is a PSU issue does anyone have a link to a replacement please?
Yep happened to me. 9£ on a replacement and no issues.Common issue with the default PSU. Happened to me.
Read the voltage and amperage on the PSU and find a replacement on Amazon.
Nice, I'd be interested to see the viewing angles of both, and the performance at night. I want to point them at my rear fence and cover the side garage door, there is no light at night so IR is very important, and I'd prefer not to have to buy a separate IR flooder, although at a push this is definitely possible. The dome would only really be installable at ~10 metres on a soffit, whereas the bullet obviously has a few more options and I've actually got a perfect spot for it with an existing cable run (its an aerial but I can utilise the same route).I’ve got G5 domes and bullets, what do you want to know?
Yeah I've come across this but I'm reluctant to start tinkering with a video system, I literally want to just plug in a camera and forget about it. Its a shame that (4k) unifi cameras are so expensive.I was just about to ask if you could use non-unifi cams with Protect using the open camera protocol RTSP, but I googled it and found this.
Has anyone used it, or something similar?
Reddit - Dive into anything
www.reddit.com
GitHub - keshavdv/unifi-cam-proxy: Enable non-Ubiquiti cameras to work with Unifi NVR
Enable non-Ubiquiti cameras to work with Unifi NVR - keshavdv/unifi-cam-proxygithub.com
The novelty of checking camera soon wears off after a couple of days.
I only look at them now if I need to (mainly doorbell) or very periodically to check they actually work still.
I may be reading something into this that isn’t there and I mean no malice by saying this, but that’s not normal.I disagree, I have all my cams open on another monitor the majority of the time my PC is on streaming live from Blue Iris. It feels very odd now if I can't pull them up in an instant.
Looks at errors on port insights.Has anyone had "experiencing transmission and reception errors. This may indicate a problem with a port or cabling." errors since 3.0.20?
Just upgraded from a security gateway pro to a dream machine pro and got this on the cable run connecting my desktop to my the DMP.
Never had that error before getting the dream machine pro, so not sure if the new software is more sensitive to catching errors that weren't seen before, or if it's something I can ignore?
I used a cable tester when running the line and all 8 cores are sound.
