- 25 Nov 2005
Wouldn't it just be a gelatinous blob ?
Guessing it's teeth?Wouldn't it just be a gelatinous blob ?
Not even that according to one "expert" in here:
"Essentially yes - almost everything atomised - it essentially had to survive being squashed in all directions by hundreds of thousands of tons of force, and the pressure cooked at 5000 degrees celsius, and then blown up again at thousands of miles per hour once the implosion bounced back out a few feet.
Basically, not much left, except hardy parts like titanium lumps of metal - the rear of the sub was likely protected by the titanium end cap, and blown away when it happened."
So they think they have filtered human atoms from the depths of the Atlantic search area. Interesting....
TBH explosions/implosions and so on are funny things - you can have things utterly decimated then some part remaining basically untouched somehow (I'm guessing there is a physics explanation). Seen lots of instances of it from the Ukraine war, etc.
So everything inside the pressurised capsule that was instantly depressurised is evaporated into molecules?
Or would there be parts say larger then a finger length?
I remember a lecture, years ago, talking about the problems with carbon fibre, and how it took the aircraft industry a while to perfect it because it kept on developing fatigue cracks. They used aircraft technology on the sub, but the thing is that the pressures on an aircraft or spacecraft are absolutely nothing compared to a deep sea trench. What's a few bars compared to four hundred?
The wreckage looks pretty intact?
Without knowing the full construction of the sub the pieces we may have seen in the Sky News report could be fairings and not part of the pressure hull so they may not have seen the same forces.The wreckage looks pretty intact?
Surprised how much of it they managed to recover and also in pretty short time.
not really decades - the other submersibles had different markets - taking samples - Titan spartan interior, screens, limited manual controls, from Musk school of design.
from the Musk school of design.
They could construct some new hulls to test the limits although I'm not sure how viable that is in terms of costs and how CF works in regards to slight nuances in the weave may react differentlyI have no idea how they are going to remotely figure out the exact failure mode.
