- 28 Dec 2017
- Beds
Triple BOGOF, triple post?
I've got a DAS 6 pro and a Medium Heavy Cutting pad and a light medium polishing pad that I bought ages ago one a whim. But now I'm thinking I'm gonna polish and wax the car next week.
Can anyone recommend some polish and wax I can use with this?
Also, can I wax the car with the DAS6 or is that just for polish? Sorry for being a total n00b, any advice is appreciated.
Bought a new car as we’ve had a child and it’s obvious the Polo just wasn’t going to be practical enough.
So today was the first clean. Although it looks clean in the picture it became apparent it wasn’t as clean as it seemed. So a quick pressure wash and shampoo meant it was ready for a full decon.
Probably the dirtiest car I’ve ever owned and goes to show it might look clean to a dealer, but it probably isn’t if it’s done properly.
On to a polish with some cherry glaze which I’m quite impressed by.
Tomorrow it shall be sealed and then waxed but I’m happy for today.
A deal too good to pass on!![]()
Hybrid Solutions | Turtle Wax
Turtle Wax Hybrid Solutions line is a complete collection of exterior car detailing products with proprietary ingredients to give your car that pro touch.www.turtlewax.co.uk
I've ordered !![]()
Autobrite Purple Rain for iron fallout.What decon product did you use?
If I were to use Megs Gold class shampoo in a in a pump Foamer will it give me decent foam or do I need a dedicated foam product like BH Auto Foam?
For application on wheels. If rather stick to one product if possible.
That looks great.I imagine it would provide a good consistency of foam.
Can’t imagine it would work out particularly economical though?
In my IK Foamer I’ve used the following with great success.
Autobrite Wheel and Tyre
Autobrite Citrus Wash
Roughly 100 ML Product and the rest water. Picture below is Citrus Wash at the above ratio.
That looks great.
That citrus wash is about £12 a litre so about the same price if not more than the gold class shampoo?
Ah you probably buy the 5L for £26?
Yes will do. I have 2 bottles of the gold class from previous sales.I’d give it a go if you already have it and see how it goes.
I imagine it will produce thick foam.
I actually paid £18 for 5L - But those days are gone![]()
£18!...That was a mega price.
Also how far do you fill up the IK.... 1 Litre or 1.25?
thanks, so would i just use this with the DAS6 pro? I wouldn't need to separately wax and polish it?![]()
Scholl - S20 Black 1-Step Compound
Scholl - S20 Black 1 Step Compound Scholl S20 Black is a true one step compound that's designed to both correct weathered and scratched paint whilst at the same time leaving behind a mirror gloss. This makes Scholl S20 Black a fantastic detailing compound as it's possible to vary the amount ofwww.cleanyourcar.co.uk
