- 19 Oct 2002
- Shakespeare’s County
Sold Defender, collection tomorrow, my peak garage lasted 7 days
Don't you get cheap leases? Or have they stopped doing them? Isn't that one of benefits of working at a manufacturer.Sold Defender, collection tomorrow, my peak garage lasted 7 days![]()
Sucks don't it!? Mine is right in my eyeline.Same in my cupra. Also on 27th. It takes some interesting corners. Mines now like a hook
my original got broke because I let the wiper arm fall back against screen when changing blades - I payed - screen was pretty scratched thoughGenuine 35 year old BMW top-tint windscreen cracked...
On the plus side, I'm off to Royal Steering Wheels tomorrow.![]()
OEM discs and Pads they are Brembo I replaced them because one disc was warped, not sure how as they are hardly doing any work considering their size.Nice what brand discs did you go for, OEM? You got a resonator delete?
Looks great! If you don't me asking, how much was that? My mk7 Golf R steering wheel could do with retrimming? Did you remove/refit the wheel yourself? Difficult?The result! Safe to say, I'm very happy.
But why? It's primarily an electrical waterproofing spray. There are better products for general rust proofing and undersealing?Bought some LANOGUARD MOTO ELECTRICS SPRAY
https://www.lanoguard.co.uk/collections/all/products/lanoguard-moto-electrics-spray
Crawled under car on my back and using a torch to see where to spray, sprayed all over this pipe to treat it for rust...
Cheers! It was £200 plus £25 fitting. Went for their exchange and fitting option, they're only about 20 kind from me which is handy.Looks great! If you don't me asking, how much was that? My mk7 Golf R steering wheel could do with retrimming? Did you remove/refit the wheel yourself? Difficult?
Says on the bottle "Easy Underbody & Rust Protection"But why? It's primarily an electrical waterproofing spray. There are better products for general rust proofing and undersealing?
Yes.Not so much what I’ve done to my car but can anyone shed some light on how reliable or unreliable Range Rover evogues are?
Currently got a BMW 4 series coupe and we’ve recently just got ourselves a new puppy so there will be a lot of travelling involved with the puppy and crate etc and the 4 series is just not adequate for that.
Looking at an SUV style rather than an estate.
Looking at models newer than 2018, if anyone can give some insight to issues they’ve had etc.
Cheers
Does the overlap of the alcantara on the left hand side vs the right hand side not bother you?The result! Safe to say, I'm very happy.
