Looks like they is next to nothing in it to be honest or even any other bios for that matter I'll leave it on gaming oc biosAnyone here with a MSI gaming trio x 4090 which bios do you run silent or oc ?
The 4080 is very efficient and the Ventus has a huge heatsink. I would be shocked if it didn't run cool and quiet.Anyone know if the 4080 ventus is any good heat and noise wise?
They re usde the 4090 coolers for most of the 4080s. Total overkill but not a problem as long as your case can handle it.
Said it before and will say it again. The 4080 is a great product at a terrible price. Great performance at decent power used but the price just sucks and is the reason it has sold so poorly.
Nah I wouldn't say so, if it's a bit bigger it's fine as it means a cooler and quieter card.They re usde the 4090 coolers for most of the 4080s. Total overkill
After buying a 3080 Ventus as that was the only one I could get at launch I personally wouldn’t buy another ventus series card, power limits were locked and while stock performance was ok the card just felt cheap and tacky.Anyone know if the 4080 ventus is any good heat and noise wise?
Agreed I had a 3080 ventus that was admirable in that it performed very well at stock levels but had minimal OC headroom and looked a bit cheap. I got my ventus for £945 during the mining craze. Not worth more than £500 at the time! Sold it for a minor loss of £150 just before 40 series and ran the 60ti FE instead. The FE was so much better built vs the Ventus.After buying a 3080 Ventus as that was the only one I could get at launch I personally wouldn’t buy another ventus series card, power limits were locked and while stock performance was ok the card just felt cheap and tacky.
Might just have to use a 4070 FE and save up for a 4090 FE. However, it is one FE per customer isn't? I am only interested in redoing another Formd T1 for transporting easily. The Sapphire cards I wanted will not go in unfortunately and I do not like any of the other models which will fit (MBA or Pulse).After buying a 3080 Ventus as that was the only one I could get at launch I personally wouldn’t buy another ventus series card, power limits were locked and while stock performance was ok the card just felt cheap and tacky.
The Inno 4070Ti would work in the Formd T1 as that's a dual slot 70Ti - although like anything with that case it also depends on what CPU / cooling you're running.Might just have to use a 4070 FE and save up for a 4090 FE. However, it is one FE per customer isn't? I am only interested in redoing another Formd T1 for transporting easily. The Sapphire cards I wanted will not go in unfortunately and I do not like any of the other models which will fit (MBA or Pulse).
I run on the OC (Gaming) bios. Not a noticeable difference in sound for me so why not?Anyone here with a MSI gaming trio x 4090 which bios do you run silent or oc ?
I don't think it's one per customer? I caved and bought a 4070 recently and remember seeing could add more than one so am sure could buy a 4090 later.
Was hoping to skip this generation but being without a GPU and wanting to pick up a few games again especially as autumn seems to have arrived early, as well as my aging system struggling a bit using iGPU(9900K) in some apps, so I went with the minimum I could get away with at 1440P. As an occasional gamer it's all I could justify, at current prices.
Bit of a side-grade from a 3080 I had some time ago but does have some benefits, like DLSS 3 where supported, extra memory and much lower power usage than the 3080.
Interesting how does one do this please? and do I have to update each bios version silent and gaming? Reason I ask I have a problem with my MSi Gaming x trio 4090 it seems ... sometimes ill turn on my pc graphics card is lit up etc but in games its stuck at 0% and have bad fps etc doesn't do anything and the fans are not spinning!!! so I have to reboot the pc 8/10 this fixes it but it is annoying!!!!!I run on the OC (Gaming) bios. Not a noticeable difference in sound for me so why not?
I also have the firmware of the card fully updated via MSI Center.
If I were you I would wait and save money.Rumour is September release date, I've not found anything concrete yet beyond a screengrab of an offer
I guess I should wait for the 4000 series? I have a 1080ti, and I can get a 3080ti.... but why get now when 4000 is coming?
AD103 4070 you say? Could it be the 16GB 4070 of our dreams?![]()
