- 17 Mar 2017
- Manchester
The Cablemod adaptors melting into the GPU socket is a different issue hence expect V.2 of their ****** adaptors soon, These that are melting are fully inserted it's just because the cheap parts like terminals and the circuit board causing the heat build up.So yeah it is user error if a connector melts and it happens because they stupidly removed the confidence inducing locking mechanism sound.
I installed a Be Quiet! Straight Power 12 PSU recently which has two 12VHPWR connectors PSU side. I have confirmed all four 12VHPWR cable connectors are properly fitted.
I made sure both 12VHPWR cables were properly fitted with the locking clips confirmed as locked in place. It's virtually silent when the locking clip is engaged which is a dumb mistake by the people who designed it.
Evidently it is possible to plug in a 12VHPWR cable where it looks like it's installed properly but without having it locked in place and it doesn't take much for it to become loose resulting in the potential for a high resistance connection causing temperatures well beyond 100c.
The cables melting are user error as far as I can see, One's that have melted either couldn't prove they were connected fully or they couldn't even back themselves up to prove they were connected properly.
Imo and yes I am going to say it, No one should be using any join in-between a 600w connection not even Cablemods revised adaptor when that lands, Doesn't matter how good they say their new adaptors will be it's simply adding another 2 resistance points and at these wattages is just stupid. Direct cable only as far as I am concerned.
