Well, when you put it like that - makes sense. Cheers.
Yep. Cat 5/6 cable is the way to go imo
Or just run it underneath floorboards if you canNot me, no; Mine was asked to be run further in from the get go, and thus was already in place where I wanted it to be.
But I'd like to ask if there a reason why you can't or don't want to just keep the termination point where it is, keep the Modem hooked up there (neatly and tidily, out of the way) and then run a single Cat5e/Cat6 cable (something that can take more harsher bends and turns) into the Utility Room to connect to whatever you have (or intend to have there) as required instead?
Since the ONT externally is powered by battery outside, and the inside is only reliant on your Modem to connect to it and keep the connection live before you connect it to the utility room. And it's unlikely to need frequent reboots or anything like that anyway either.
Neither the ONT nor Modem as far as I can tell makes a sound, so should be fine for a Bedroom, especially if tucked away so none of the indicator LEDs on the modem blink/flash to disturb the occupant.
Aye, that's a cleaner alternative too.Or just run it underneath floorboards if you can
 But not an option for everyone (I know mine isn't such an option unfortunately
).Well, when you put it like that - makes sense. Cheers.
Got 1 gig installed this morning, £25/m and 6 months free.
Router is great and I've upgraded from BT FTTC, latency and speeds are a lot better. I get 1ms to 8.8.8.8!
I think around January-February. It was available to buy a little after but I waited a little since I already had a contract with BT.Very good indeed.
Was you waiting for it to become available like me? If so do you recall when the black box on the utility poll was connected?
Ah, I feared that might be the case. Probably worth keeping the BT cabling + box in place then, just in case I want to move back at some point.New cable, new ONT. They are separate networks.
I was on BT fibre before and can confirm that they used a different cable + ONT. Also worth considering that due to wiring differences the ONT might be put in a completely different part of the property. Also worth considering that they may use different entry points compared to BT. For me BT entered via walkway at front of flat whilst community fibre wasn't.Ah, I feared that might be the case. Probably worth keeping the BT cabling + box in place then, just in case I want to move back at some point.
Unless there's a dud connection issue with CF (which you'll know in the first week if not first day), I doubt you'll be moving back to BT any time soon. BT identical download speed packages are asymetrical, so you only get like 300mb/s up, rather tha 920mb/s up on the 1gb/s package. Assuming you never upload anything, you're still constrained by the fact that BT currently doesn't compete on price to CF.Ah, I feared that might be the case. Probably worth keeping the BT cabling + box in place then, just in case I want to move back at some point.
Good shout, I hadn't considered that. BT's entry point was always be a bit restrictive, having to route cable throughout part of the house. Hoping the CF route might be more accommodating!I was on BT fibre before and can confirm that they used a different cable + ONT. Also worth considering that due to wiring differences the ONT might be put in a completely different part of the property. Also worth considering that they may use different entry points compared to BT. For me BT entered via walkway at front of flat whilst community fibre wasn't.
But, I will agree having options is good. Just, you're unlikely to go back. Not until BT gets their stuff in order.
Ouch, I must be remembering the talk about updating it to 300Mbps up then. Even worse then, but as @Tejstar already said, the price comparison is already a loss for BT. 500Mbps vs 3Gbps for the same price. Not a good look.Even worse than that, currently the highest on a 900Mbps BT/Openreach package is about 110Mbps upload.
Come renewal you guys on community expecting the same price you paid in your first contract?
I'm guessing it'll go full price with little wiggle room.
