- 23 Dec 2022
- London
Imagine sharpening needs to get more love.
Radeon image sharpening.
Does anyone use this? I never see it mentioned and I always enable it. I think it looks great.
Not sure what one you are using. I use the latest MSI afterburner which is fine.If I use an overlay to monitor temps etc. I'm getting the GPU crash in game (CODs DMZ). It's fine running 3dmarks.
I use the inbuilt Adrenalin one and experience no crashing. I had an issue with crashes early on and realised I had a dodgy psu (RM850x) and swapped it out for a RM750x which fixed the issue.If I use an overlay to monitor temps etc. I'm getting the GPU crash in game (CODs DMZ). It's fine running 3dmarks.
Yeah, great feature and can really help. Currently using 80 at the mo.Radeon image sharpening.
On MAIN Window, left hand directory panel>expand on Video Adapter>select AMD Radeon RX XTX7900.I couldn’t see where to find it on HWINFO.
Never used Image Sharpening, need to give that a try.
Any pointers?
You can set it up globally or apply it per a game profile. Don't use it if you use FSR, otherwise you can use it with anything.Never used Image Sharpening, need to give that a try.
Any pointers?
I enabled it in Adrenaline’s software theres a scale to adjust to your preference. Ive just left it set to default and it looks crisp to me.
Depends on the game, somewhere between 50-100 works for me. 100 is good for old games that are not great graphically (eg Football Manager).Cool, any starting no. to try, seen 60/80 mentioned above, is anything applied at default on(without changing anything else)?
Ok I don't think it's an overlay that's is causing my driver crash.
If I leave the GPU at stock it doesn't crash in 3Dmarks or game.
If I undervolt it's stable on 3Dmarks. But crashes the GPU in game.
I hops this makes sense.
