- 23 Mar 2011
I don't suppose anyone here has a firmware beta code going spare? Id like to try the atmos addition but unfortunately didn't get selected
I had this more so with the Steam Deck.Happened to quite a few of us. I barely PC game anymore.
I then took my pc to work to use there for CAD/CAM As it was just sat here doing nothing!
PS5 and a handheld is ideal for my tastes these days.
Looking for a set of black plates too now as my ps5 is moving into the living room tomorrow.The black plates have unfortunately been impossible to get hold of for months. Even PS Direct hasn't had them in.
That drive detachable?Seems that picture of the "slim" is legitimate or a very well done hoax. If it's real i'm glad i've got my fat model as i hate shiny plastic.
It's been suggested that whole panel comes off below the seam. And if you buy the optional user replaceable optical drive and attach it you have a console you see in the video. By default it would just be a blank panel.That drive detachable?
Could be that's a main production replacement and there's an unseen slim coming too. 5cm shorter doesn't really constitute 'slim'.
Maybe, maybe not.
I'm currently playing Ragnarok, I forgot how hard GoW can beJust grabbed God of War for £8 to play on my PS5, never played a GOW game before.
I did mine last year and yeah there was a lot of collected dust in there. I took the fan off as well and gave it a clean. Need to give it another go soon.I finally cleaned the inside of my ps5 today. I've had mine since a month after launch and was amazed how dirty it was inside. I literally just took the side panels off and used the vacuum hose inside and then wiped down with a microfiber cloth. It looked like new again by the time I'd done. I will leave taking the fan out for now as I couldn't find my torx screwdriver set but they didn't look too bad.
I tested the ps5 straight afterwards and it booted silently with no problem. I think I might start doing this every 6 months from now on.
Yeah I thought FoV was bit low myself too, I know I had bad headache yesterday but just put it down to playing to close to my LG CX, can't wait to get smaller C3I played a little and tweaked the settings but the FOV is giving me a headache. Shame as it looked solid.
Did you make sure blow out the PSU at the bottom? The inlet holes can get clogged.I finally cleaned the inside of my ps5 today. I've had mine since a month after launch and was amazed how dirty it was inside. I literally just took the side panels off and used the vacuum hose inside and then wiped down with a microfiber cloth. It looked like new again by the time I'd done. I will leave taking the fan out for now as I couldn't find my torx screwdriver set but they didn't look too bad.
I've not done that - but it's a good call I've seen a youtube video advising that not keeping the psu inlets clear of dust can lead to failure.Did you make sure blow out the PSU at the bottom? The inlet holes can get clogged.
