Not sure then, it might not be possible.Yeah i found that but in Solasta you see the dice roll for every combat action. I quite like seeing it.
Used a bottle of grease to slow the enemies approach so I could loose more arrows at them. Killed one with a fireblast and the burning corpse set the grease on fire. AWESOME!!!!Combat also has another level of depth when you bring in other elements. Getting enemies wet (spells, throwing buckets etc.), standing on boxes for height or getting to ledges.
Not if you are at the start (around the Nautiloid ship), there are 3 companions located very near the start point and more become available through out the rest of the game (depending on your previous actions).Sounds like I've done something wrong only having gale as a companion should I start again from scratch?
There is a possibility that if a particular route is taken, you could end up missing everyone from your first go and reach the refectory area. Ultra remote chance, but not impossible. @rumple9 should try and grab a lotto ticket.Not if you are at the start (around the Nautiloid ship), there are 3 companions located very near the start point and more become available through out thee rest of the game (depending on your previous actions).
just wondering if you can come back to act 1 areas later?At various points in your story you lose access to some places. Trying to be non specific.Do you relaly need to get into the Adamantne forge in Grymforge? That whole zone is doing my nut in , trying to navigate around it. I'm on the verge of ending act 1 now after 35 hoursjust wondering if you can come back to act 1 areas later?
No you haven't done anything wrong, you just need to find the other companions.Sounds like I've done something wrong only having gale as a companion should I start again from scratch?
I found the passives tab when I had to goggle on how to turn off the knockback on my 'locks eldritch blast. Its just hiding in plain site.I just found a spell in my book called "non lethal blows" you can toggle this and you wont kill stuff.... odd this isn't made more obvious, maybe I missed it?
I'm not the only one who is doing thisand haven't completed it yet - because I keep going back and creating new characters and playing them to try different classes!
On my third run, (stopped at Lv 7 and 11 so far)I used knockout mode against some people that were under the charms of an old hag, but they were all dead after. Not sure what occured.I just found a spell in my book called "non lethal blows" you can toggle this and you wont kill stuff.... odd this isn't made more obvious, maybe I missed it?
Gotta be a bug surely because I saved them by killing the hagI used knockout mode against some people that were under the charms of an old hag, but they were all dead after. Not sure what occured.
YepI just threw a water bottle at a flame launcher device and it rendered it useless. Just these little touches and different ways that make you think outside the box.
I can recommend Native Camera Tweaks over on NexusIt does have some issues with camera angles
