My XTX has arrived today. Wonder if someone can advise on a couple of things;
It has a backplate, but it looks to be sagging - are the items in the box a support, or are they for vertical installs? The manual just says "holder installation guide". Looks easy to fit together, I assume the base is magnetic, and the support just goes under the far end where the plastic is and away from fans and metal? It includes two supports but only one pole, not sure how the second would fit?
Secondly are the fans meant to spin all the time? They spin a bit on start and when I shutdown so obviously they do work. All I've done so far is install the O/S so it may be they only spin as needed or I need to add drivers but seemed odd to me.
It's an XTX Hellhound if the model helps.
