- 20 Oct 2002
- Oxfordshire / Bucks
I don't disagree with any of this, all very valid.
However I'd probably suggest just coating the wheels in a dedicated coating. It's a simple enough process.
well, the Wheel coatings are designed to take higher tempretures apparently
Im thinking of switching brushes to these then :
Fluffy Thumb Wheel Mitt
Our new wheel wash mitt fits fully over the hand and has a thumb insert to allow accurate cleaning of alloy wheels.Soft and fluffy material enures it is safe to clean even the most delicate of wheel finishes.Created from the same soft microfibre material as our high quality Korean wash Mitts and...
www.in2detailing.co.uk
Gyeon Q2M Tire (Tyre) Brush
Superb maintenance products for outstanding detailing performanceStiff yet gentle synthetic hair, placed in a chemical resistant handle and an ergonomic shape combined in the Gyeon Q²M TireBrush to offer you safe and comfortable tire maintenance.Safe and ergonomicThe Q²M TireBrush is designed to...
