7800x3d is tempting, however system VS system it's more expensive than 13700k with DDR4...
It’s also a good bit better
How much performance is lost to DDR4 vs DDR5?
That is a selling point, you don't need top end RAM to get the benefit. One reason I just bought a 6000MHz CL36 kit for my AM5 system, should be plenty with an X3D chip.Most of the testing is 8 months old and only using 6000mhz loose ram, but it’s about 3-8% in that testing.
But if you was running newer 7600mhz good timing ram in north of 10%
The 7xxx 3D chips is where you need to be right now. Even with slower ram is ripping stuff up
Yes B650 motherboards have come right down. You could get a decent one now for £169 plus £125 for 32GB DDR5 6000 and £368 for a 7800X3D. £662 for a very fast PC with plenty of room for upgrades.If you're getting 13'th gen for gaming why would you get it with DDR4? its even slower with DDR4, its not like getting it with DDR4 is just a cheaper alternative vs DDR5, its objectively slower, significantly.
Might as well get a 5800X3D.
He wants 64gb of ram
For gaming?
I keep hearing this but haven't found reliable benchmarks, do you have any good links that aren't youtube tirades?If you're getting 13'th gen for gaming why would you get it with DDR4? its even slower with DDR4, its not like getting it with DDR4 is just a cheaper alternative vs DDR5, its objectively slower, significantly.
He said for Machine learning
You'd be surprised at how many machine learning algorithms are still single core...Wouldn't machine learning be better with more cores? Make use of the e cores ?
Ok, do you have any source for your claim?Everything is Youtube now.....
That makes sense, Intel or AMD it shouldn't matter....
I'm considering 7800x3d VS 13700k.5800x3d is purely gaming CPU imo , I wouldnt be looking to buy it if you also need to do other stuff, and intel single core is really good
I don't see huge differences TBH.![]()
i5-13600K - DDR4 vs DDR5 - Worth Spending EXTRA Money?
i5-13600K DDR4 vs DDR5 - RTX 4090 and RTX 3080 - 1080p and 1440p Benchmarks0:00 - Test System0:15 - Cinebench R23 Score0:24 - Corona 1.3 Benchmark0:33 - CPU-...youtu.be
@humbug, this seems to contradict your claims: https://overclock3d.net/reviews/cpu_mainboard/intel_13600k_and_13900k_ddr4_vs_ddr5_showdown/16
Ok, averages does show an improvement, however it compares cheap DDR4 VS higher end DDR5...Watch more than the first two games...
