I forgot to add the video to my post was all.@LtMatt
Poor form quoting yourself unless you’re trying to win an unwinnable argument in the GPU forum.
Hope my 5950X doesn’t hold back my 4090FE too much when I get a chance to play on Wednesday.
Finally downloaded the preload at least.
Just pointing out that FSR does not lower performance if you are using suitable hardware to drive that 4090. I'd imagine you will be CPU limited once the FPS goes past a certain value with a 5950X.
I suggested upgrading the CPU. I included three examples in my post showing FPS increasing with FSR enablement and GPU utilisation being locked at 99%-98% in response to a claim that FSR lowers FPS. It doesn't if your CPU is up to the task and your hardware well matched. The 4090 needs a top tier CPU to get the most from it.Pretty bold of him to tell someone to upgrade their CPU/whole system, when we have no actual benchmarks to test if it would be even worth it/make a big difference.
) hopefully there's some quick patches/driver updates to fix those crash issues.
