Groan.....I didn't know you could walk a dog? Is that a new fan made mod? Did they add the dog from Fallout 4?
Any suggestions on what I should actually 'loot' or take? Classic bethesda game where there are LOADS of items everywhere. Screwdrivers/drills/plates/cups etc etc etc.......is any of it worth taking? I've noticed you can't 'dismantle'weapons, only sell them.
So can this be played with a controller or is mouse and keyboard the superior option?!
Quite like the idea of playing with controller on the laptop but if it's better with M&KB I'll go that route
microscopes and rolls of tape..spot the fallout 4 player
turns out they are no use at all![]()
What do you do with these resources? Make ships?
Dude, that is still a txt file
If you don't know how to make a ini file just copy paste the ini file that is already there, rename it, open it, paste over what's in there. Done. 1 minute tops.
OK, played it for a few hours. With my new potato pc(Ryzen 7 5700X and RTX3060TI) a QHD on medium settings, high crowd density, no upscaling and no dynamic resolution getting between 35~60FPS. Game is quite smooth despite this. Also using old drivers so need to see if the new ones help.
So I started with the ship builder last night after the last dog walk around 10ish, nearly 1am and was still faffing around, I'll try again today.
No, don't bother with those.
Forgot to mention. The next skill I have started leveling up is the booster pack. I am in working on that now while also trying to level up lock picking and less of a priority is medicine.
After that will probably go for some more tech stuff![]()
Is there a way to reset skill points? I haven't noticed anything that allows you to do it.
Weaponry is good because you then do more damage with them. I use rifles almost exclusively so put some points in that. I found a legendary rifle that does random elemental damage so that also helps. Loot every corpse for ammo, you’ll need it and it doesn’t have weight either.Level 6….haven’t used a single skill point because I can’t decide what to skill up![]()
