So what ultimately is the solution here?
- if you use the cablemod adaptor or direct PSU cable/nVidia cable you may still have a failure.
- if you have a failure and manage to get your card repaired/replaced, will it not just happen again?
It’s starting to sound like we all should get replacement cards with the revised connector.
I say this as someone with a recent 4090 with an 80% power limit in place and a 90 degree cablemod adaptor very firmly pressed in.
