For pooed through carpet ?That's the Swedish recipe?
Replacement is not reasonable in any way. Offer to have it spot cleaned and if not say "see you in court".
I’m a bit confused by the string of events. Can you explain in detail exactly what has happened
Did you move their old pc and the stains were there? did you put the old pc somewhere else which then got marked?
Never though of the spot clean, posted on fb to get some recommendations thanks.. Considering the filthy delipaded state of the house ill feel bad asking someone to go there..Replacement is not reasonable in any way. Offer to have it spot cleaned and if not say "see you in court".
The plastic feet have disolved and have the consistency of thick oil, I've handled probably 1000s of pc's and not seen that before.How was this mark caused? What on the bottom of the PC caused it?
Anyway, PCs generally do not mark carpets, you have not acted unreasonably. I don't see how they can hold you accountable, it's their equipment that is at fault, not you.
If it can't be cleaned then I would consider obtaining a patch to put over the stain, but if they want a new carpet, they'll have to buy one. I think they are taking the mickey.
It was on a desk I put in on the floor as I installed a new one for him and he asked me to take the old one away. He is disabled and cannot lift anything (i don't usually take them away as I cannot legally dispose of them, it's commercial waste if I take it to the dump)When did the PC originally go onto their carpet?
I've never heard of PC feet leaving oil marks on flooring before. Part of me wonders if you were setup for this, so they could get a new carpet out of you.
Google how to remove oil stains and don't give up on the stain.
I lifted the old pc of a desk and put it on the carpet
I already did the pc / screen at cost to help him out as he is poor / had a stroke plus I have done probably 5 free visits over the years to help him with various computer issues!Just tell them straight, carpet's gross, no chance. Try clean or scissor it if they agree, and if you feel they are genuinely not scummy, then give them near cost price on computer. If they are scummy, just walk, you're wasting your time hoping for a good outcome.
Why? It's the customer's PC, the customer asked for it to be moved. How is the OP responsible for that?OR request a professional cleaning service for the portion of affected carpet at my cost.
