Permabanned
- 7 Aug 2017
- by the tower the one up north ..
so waiting for wife to finish her film and we are going to switch everything off ect for fridge .. see if there is still a draw ????
I'd suggest not looking at p per hour and rather look at watts / kwh per hour. It removes a variable from the equation and gives you a number you can match to appliances etc.yep it's going between 11p/13p ph
It is a good place to start.so waiting for wife to finish her film and we are going to switch everything off ect for fridge .. see if there is still a draw ????
no .. and shes on the pc .. we rarely use the tv ..It is a good place to start.
It isn't an old plasma telly by chance is it?
Your neighbors must be plugged into your houseno .. and shes on the pc .. we rarely use the tv ..
. Definitely switch everything off and get to zero, then build back up. Something is rinsing you.but yet they still make millions in profits ?
atm it's 463w .. with me playing apex and her watching films .. our front room is different to most it's set up as a game room both pc's are in it so it might be right ..I'd suggest not looking at p per hour and rather look at watts / kwh per hour. It removes a variable from the equation and gives you a number you can match to appliances etc.
back room and outside are for guests ..
Maybe look at getting/borrowing a plug-in power meter/energy monitor. Then you can see in real time what that particular appliance is using...Your neighbors must be plugged into your house. Definitely switch everything off and get to zero, then build back up. Something is rinsing you.
Hefty graphics card? That'll do it!atm it's 463w .. with me playing apex and her watching films .. our front room is different to most it's set up as a game room both pc's are in it so it might be right ..back room and outside are for guests ..
Known as the “Big Six”, the companies including EDF Energy, E.ON UK, and British Gas’s parent company Centrica, recorded profits of £3.06billion, according to their most recent accounts. ????Millions is nothing
Something like 20-30 million consumers
vega 64 .. ?Hefty graphics card? That'll do it!
200-250w probably.vega 64 .. ?
TDP295 W - if you're maxing it out?vega 64 .. ?
Power consumption is about as bad as it gets on those --vega 64 .. ?
yeah i'm thinking that now ... mines on the med side of things hers is lower ... but other than days off there only running 4-5 hrs a day .. we both work 9+ hrsMaybe look at getting/borrowing a plug-in power meter/energy monitor. Then you can see in real time what that particular appliance is using...
/edit what's the spec of your gaming pc @flea.rider? Two PCs running could get to 400w easy, I reckon?
might be cheaper to get a new card .... lol 7800xtPower consumption is about as bad as it gets on those --
https://www.anandtech.com/show/11717/the-amd-radeon-rx-vega-64-and-56-review/19
That's the full PC though?It hits 460W in this review lolAnandTech Forums: Technology, Hardware, Software, and Deals
Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.www.anandtech.com
so everything turned off 44w which would be the fridge ?? i'm pulling 144w ..and 460w in game shes pulling 200w .. ffs what an eye opener ...Power consumption is about as bad as it gets on those --
