I forgot unfortunatelyDid you guys use Topcashback with your very orders? They have 8% cashback as well.
I forgot unfortunately![]()
The annoying thing is, when I was first going to use the 10% offer from a different store I did remember to check cashback! Ah well.Ahhhh nvm, im only asking cos i use it quite often so just wondered. It's quite abit of saving to be had.
I assume we're going to be able to do referrals for the free $30 credit when activating our Quest 3's, afaik we can't post them in this forum, so how do we them? By PM? Or I seem to remember there was a sub-forum on here somewhere that could be used?
Hope it's not just the brand new users, will have a read around to clarify.Don't know, might only be the brand new users that can take advantage. I'm not opening a new account to get it, since I've got a lot of games already on my account.
Thanks have created a thread there.
I'm obv not l33t enough to be able to get in there
.. not that i've purchased a Quest 3.. but i've still got 6 days to change my mind
Not sure if this is the right place but if I wanted to dabble in PCVR without buying a 6E router can I just plug it in via cable into the PC?
Yes you can use a USB cable, the Meta one is expensive, some 3rd party one's are ok and much cheaper, I used an Anker cable from the rain forest.Not sure if this is the right place but if I wanted to dabble in PCVR without buying a 6E router can I just plug it in via cable into the PC?
Think it's part of members market so 1000 posts, you'll be there in no time considering iirc you had 3 at the bot scandal of walkaboutI'm obv not l33t enough to be able to get in there.. not that i've purchased a Quest 3.. but i've still got 6 days to change my mind
It was my 2nd post in the social thread.. I did post in the hello members first.. (after stalking you all !!Think it's part of members market so 1000 posts, you'll be there in no time considering iirc you had 3 at the bot scandal of walkabout![]()
)Not sure if this is the right place but if I wanted to dabble in PCVR without buying a 6E router can I just plug it in via cable into the PC?
you don't need a wifi 6e router, most people use 5GHz ones fine on the Quest 2
The Quest 3 "supports" "upto" 6E, but you don't need it, depends on your situation etc
Just phoned very I am getting the £100 credit. It will show in my account once the quest is dispatched.
6E isn't necessary but it just works better as it's a much less congested spectrum, plus the bandwidth means you can up the bitrate and get wired quality using wireless.
For most people 5Ghz is fine, it's just there is a quality drop compared to cable (which isn't noticeable in most games but some games like Skyrim can really suffer) unless you tweak some settings and you may not be able to achieve the best quality if there's WiFi congestion.
Quest 3 supposedly supports AV1 encoding which potentially will give better quality.
