It was perfect for the malabar from Rave (max grind setting) but I am struggling to find a good grind setting for the same beans from White Rose - hence why I'm so puzzled. Max grind setting doesn't give me a consistent pour as it breaks up and drips sometimes so I back off a bit on the grind setting but it doesn't feel right.I thought your machine was spot on with the MM beans from White Rose?
Can you set your machine to a finer grind?
