Underboss
- 20 Oct 2002
- Oxfordshire / Bucks
that's faulty
mines better than that
Yep, open the meta-browser (web browser) and go to "lcdtech.info" when you start the test, it will go 'fullscreen' and just scan around, moving your head/eyes to get full coverage.. everytime you click the colour it will cycle so you can do white/black/red/green/blue..Are there any good apps for testing for dead pixels etc?
So no double image/ghosting at the bottom of the screen for you at all.? (it’s actually green not pink).
Here is a through lens photo showing it.
Nope
that's faulty
In that case I will be sending it back for sure, and yeah it is very annoying and knowing my luck the replacement will probably have dead pixels.That's what it looks like to me after a few(many) beers!
No, mine looks nothing like that. It's perfectly clear. That's annoying for you. Finally solve a problem that's been plaguing for since forever only to discover your new headset is faulty![]()
That reminds me of the cheap VR prescription lenses on my other headsets, off the sweet spot, looking down with my eyes, the prescription lenses separated the colours..So no double image/ghosting at the bottom of the screen for you at all.? (it’s actually green not pink).
It’s like that in both lenses and no I’m not wearing glasses.That reminds me of the cheap VR prescription lenses on my other headsets, off the sweet spot, looking down with my eyes, the prescription lenses separated the colours..
Mines quite blurry right off axis and at the extreme of the lens/panel, but that's right at the edge, and no distinct colour separation.
Is that in both lenses? Since it's separate panels/pancake lenses, I'd be amazed if both had some form of misalignment of panel to lens..
And you aren't wearing glass etc? Taking an image with a phone is hard you have two sets of optics that can make that kind of effect from even a good setup.
that does not sound right esp what sounds like chromatic aberration which i defo do not getThis is not the case for me as when I’m moving from the sweet spot I’m still losing a lot of sharpness albeit nowhere near as bad as with fresnel lenses.
Also when looking down there is that double image that’s greenish in colour.
When I heard people praising pancake lenses and saying you get great sharpness across entire fov I thought it will be exactly the sam as the centre but no, not for me at least.
Got another one already from Argos.that does not sound right esp what sounds like chromatic aberration which i defo do not get
Well you have kinda convinced me the 3 should be around the price it is, being the miser I am though, will still wait until its under £400, well really its the 512 storage I'm after.Can you buy a more powerful pc now for less? The graphic card forum is full of people moaning about how expensive GPUs are these days. Motherboards to support the latest GPUs and CPUs have skyrocketed in price.
Let's start with the Snapdragon Xr2 Gen 2 chip compared to the Snapdragon Xr2 in the Quest 2. It has 2.5 times the graphic power and 30% faster CPU performance. It supports 10 cameras instead of 7. And it has an MR chip. As well as that it has 8 times the AI performance. If you were making that jump in performance between a computer 3 years ago and a computer now, on the graphics card alone you would need to spend £1000 extra.
Then there is the Lenses and LCD displays. The Lenses are much better quality then the ones on the Quest 2, good Lenses are extremely expensive. Also the Quest 3 has dual LCD displays not a single LCD like the Quest 2. Which adds to the cost.
Then there is the added extras like better speakers, proper IPD adjustment, Moveable eye relief interface, depth sensor, passthrough cameras, improved build quality.
Lastly there is the rising cost electronics and increasing inflation.
So, no I don't think they could have sold the Quest 3 at the same price as the 128GB Quest 2.
I only went from 80% but USB A took a good few hours.@ScoobyDoo
charging it with dongle connected at the moment
started at 67%, in 1 hour, its done 6%
any idea how long yours took to charge? (USB-A)
it's the field of view which bugs me in the quest 2In the absence of new Q3 I just fired up the Q2 again in MSFS. Have to say its still a damn good headset. Visually, the Q3 is better but there isn't a huge amount in it.
