- 1 Jan 2003
- Derbyshire
You in Dark Theme mode?Also my bottom bar is dark on chrome so not sure what's up with yours
Ocuk grey mode?You in Dark Theme mode?
It's strange because turning the buttons on they don't use up much more space. Do what's the point of using gestures.I swap between Light and Dark mode on the Pixel from the drop down menu, usually light during the day, and dark in the evenings.
And that directly changes the colour of the gesture hint bar, from what I can see.
I really wish it was transparent, or not there at all (I don't need the hint or the bar) or would just colour match whichever app I'm using.
I had to suffer the same when moving from oneplus to Pixel. I soon got used to it and now it's no bother.Just preference I suppose, always use gestures since they moved the touch buttons off the frame (back in the day when phones had bezels) and into the screen.
I really like having all the screen real estate, even the nav bar could disappear for my liking, but full screen immersive mode doesn't seem to exist anymore![]()
Are you even sure it makes a difference. Where are you noticing it makes a difference?just enabled 120hz. never saw the point in it, but now i have seen it in the flesh, my lord. I can never go back. I forget i have it enabled and go to do something on the phone and it's just so smooth and silky.
Are you using smooth display, or did you force it in the developer settings?Are you even sure it makes a difference. Where are you noticing it makes a difference?
I turned it back off because I think it's bugged. Turn it on and its constantly at 120hz. Turn it off and the display constantly adjusts from 1hz to 60hz depending if the screen is moving. Surely the 120 mode should still utilise this feature to save battery I don't need 120hz when nothing is moving.
Normal setting. Then put the FPS on and it just sits at 120.Are you using smooth display, or did you force it in the developer settings?
With smooth display turned on mine will sit at 10, or alternate between 10 and 60 when theres no input/movement then ramp up to 120 when there's movement. Obviously if i force it in the developer settings is stays at 120 all the time
Like right now in chrome on this forum not touching the screen sat at 120.
