Don
- 20 Oct 2002
- Oxfordshire / Bucks
1st octoberStill processing for me, when did you order?
Could be a while till mine get posted then, i ordered on the 10th.1st october
How do you protect the lenses from getting dust on them when using the docking charger?
Really pleased with mine, much more comfortable than the stock strapDecided to take the hit and ordered the Meta elite strap with battery. Can’t deal with the fabric strap.
Will post my thoughts when it arrives! If it’s anything less than perfect it’ll be going back though as I expect god tier comfort and decent build quality for the price Meta are asking!
Worst case i have 30 days to try it and can send it back in the event of issues and/or if a better looking/cheaper third party option appears!
Alright, that saves me a few quid, cheers mate.put a cloth over it ?
I love my elite strap, my girlfriend also finds it comfortable too. I don’t even realise I’m wearing the headset I find it that comfortable.Really pleased with mine, much more comfortable than the stock strap![]()
I received mine today ordered off the back of your suggestion. Really pleased with it and very comfy, good fit and finish, also so easy to adjust for different users compared to the standard strap (as my son seems to use the Q3 more than I do!).Maecker
I would have felt absolutely robbed if i'd bought the official Elite strap for over twice the price, so thanks.
i'll be testing mine tonightGlad you like it. I've worn mine for a couple of hours at a time and find it really comfy, can hardly tell it's on.
I also found that tightening the side straps causes the tilt adjustment to rotate it more towards my forehead, I loosened the side straps and tilted the quest 3 forwards so it was more balanced across my face, until the elite strap turned up and that is far better, but still needs to ensure the correct 'tilt' adjustment..Well my 3rd headsets arrived, and so far I've not found any dead pixels.
but my word, after 5mins my forehead is red raw! Not comfortable at all
Just tried this in ams2 and iam blown away by the clarity. Even with super sampling in game set to 1.0 its super clear even in the far distance. This is wired btw.
i am not answering your question (sorry) but just a thought...............how slow is slow? i mean if you get 2.5hrs out of it wireless, and if even discharging slowly you get 5 hrs , then maybe it isnt worth worrying about.
are you really likely to do more than a 5hr stint without having a food break or something (at which point you can properly charge).
standalone will hit the battery harder as it is also powering that - fast but thirsty - standalone processor.
