- 12 Feb 2006
- Surrey
Thanks for explaining. I'll try and see what it's like. Can you auto change work profile at set times and days to avoid the need to manually do it?You don't change between profiles, the apps are in different profiles and effectively two different parts of the phone. I have two Gmail apps, for example. One mine, one work. You can turn the work profile off on your days off and no work things will come through. Your personal is always on, so calls, messages etc come through. Work stuff only comes when you have worked enabled. I remember trying to use an iPhone and felt sorry for my collegues that didn't have this...
(The actual answer, I have no idea, I've never looked. It really is so simple to toggle)
