I got a 14700KF from here and it's a bit of a dud. Memory will not go past 3800 15-15-15-28-2T no matter what settings and the default core clocks require 1.3v to be stress test/game stable.decided to pull the trigger on a 14700kf...should be here by tonight![]()
when you say from here....do you mean not from ocuk?I got a 14700KF from here and it's a bit of a dud. Memory will not go past 3800 15-15-15-28-2T no matter what settings and the default core clocks require 1.3v to be stress test/game stable.
My 12600KF memory OC to 4000 16-17-17-28-1T with out issue. I'm hoping a future BIOS will help but I'm not getting my hopes up.
My system
Asus Z690 TUF D4 Wifi BIOS 2802
2x8GB 3200 CL14 B Die
360 AIO
Voltges for my memory OC are
SA 1.1v
Vram 1.5v
VDDQ 1.3v
looking at the settings you would think there is some headroom. Will be interesting to hear your experience.
From OCUKwhen you say from here....do you mean not from ocuk?
I actually bought mine elsewhere so will let you know what I findFrom OCUK
I have tried. I have been as high as 1.45v SA 1.5vddq 1.55vdimm. Backed off the timings. Even some more vcore.Bump SA
I think Jayz2cents was saying that DDR4 on these chips is a bit weird, results not as good as DDR5 not sure why.I got a 14700KF from here and it's a bit of a dud. Memory will not go past 3800 15-15-15-28-2T no matter what settings and the default core clocks require 1.3v to be stress test/game stable.
My system
360 AIO
SA 1.1v
Vram 1.5v
VDDQ 1.3v
The G-skill 7200Mhz CL34 is a decent enough kit and can be had for £150which ddr5 kits are people using on the 14900 , just about to finish my purchase. pref would like 64gb at fast speed but i know 32gb kits are the only 6000+ so may have to go 32
Intel has turned FPS gains into FFS with the 14th gen:
Although the minimum FPS gains are a bit better:![]()
Intel Core i9-14900K Review - Reaching for the Performance Crown
Core i9-14900K is Intel's new flagship with clock speeds of up to 6 GHz. It's actually clocked even higher than the 13900KS, thanks to an extra 100 MHz when more than two cores are active. Our review confirms that Raptor Lake Refresh is amazing for both applications and gaming, if you can live...www.techpowerup.com
I disagree when these are the latest shiny shiny
G.SKILL Announces DDR5-8400 Kit for 14th Gen Intel Core Desktop Processor & Z790 Chipset Platform - G.SKILL International Enterprise Co., Ltd.
17 Oct 2023 – G.SKILL International Enterprise Co., Ltd., the world’s leading brand of performance overclock memory and PC components, is excited to announce the launch of a new Trident Z5 RGB DDR5 memory kit specification at DDR5-8400 CL40-52-52-134 48GB 2x24GB, aimed at the latest 14th Gen...www.gskill.com
F5-8400J4052G24GX2-TZ5RK - Overview - G.SKILL International Enterprise Co., Ltd.
Trident Z5 RGB series DDR5 memory is designed for ultra-high performance on DDR5 platforms. Featuring a sleek and streamlined aluminum heatspreader design, available in metallic silver, matte black, or matte white, the Trident Z5 RGB series DDR5 DRAM memory is the ideal choice to build a...www.gskill.com
TBH They are not that offensive, compared to what I thought they would be. Ja, you have little to zero chance of getting 8000+ working on a 2DPC board and XMP doesn't always work getting up that high so it needs a bit of tweaking. Not sure about picking them up as I have already pushed way past that on my 8200 sticks but you never knowyeah that is a nice kit but may be a bit if hassle trying to get it to run at full speed on a 4 dimm Z790 board ( non refresh )The price will also be eyewatering i imagine at the same price as the 14900k
but yeah will be rapid for sure, you done a buy yet ?
picked up a 14th gen and new Apex or waiting for the KS ?
looks like the sa voltage is high as per usual on msi motherboards, and idea of what voltages to tweak to get some lower power usage
Who the hell games at 1280x720 on a high end CPU?Intel has turned FPS gains into FFS with the 14th gen:
