Ahaha yes it’s there! Sorted.i didn't get the email either. log in and check the orders page
I was waiting for an email from them! Thanks
Pre loaded, 52GB, now to wait till 5pm...
I planned a long lunch today to give it a go and only found when it wouldn’t launch.Checked earlier on, said 'awaiting keys', just checked now and got my key. Preloading as I type...Those who ordered from CDKEYS, when are you expecting your key? An hour after release?
Xbox version should be similar up to the STEAM_ID bit.The instructions say to download the .zip, and unpack it to C:\Users\USERNAME\AppData\LocalLow\Colossal Order\Cities Skylines II\Saves\STEAM_ID They add that you might have to turn on "hidden files and folders".
Yes. It's just unpacking now, will take about 20mins.Supposed to be 5PM isn't it?
That looks worse than Sim City 4Sadly it seems that DE Benchmark file errors when loading it. They might be on an updated version yet to be rolled out
I stand corrected. I created a map, saved it, dumped the file in there and tried to load it and it gave the familiar CS1 error.
I started a new map somewhere i wanted to start, it loaded but with no GUI so i killed the exe and relaunched, and tried the save again and it works just fine.
Im getting 60fps for the most part, lowest dip ive seen is 48fps (not sure how to get more info like 1% lows) HOWEVER... things look very poor if you get quite close. Setting LOD to high doesnt seem to have fixed it entirely either .
Edit: I think i fixed it. I put Depth of Field on low, rather than Off (theres 2 settings, DoF Mode at the top and DoF Quality midway down. You want to disable it in the mode.)
Maybe it's the rain but looks like a lot of aliasingThat looks worse than Sim City 4
think I'll leave it a few days and try againso basically run it at potato settings....good job devs, you done ****** up!120fps in the splash/intro screen!!! woot
Heres the recommended things to tweak.
Start with a High Preset and then
- Use "Fullscreen Windowed" or disable VSync
- Disable "Depth of Field Mode"
- Reduce "Volumetrics Quality" to Low
- Disable "Global Illumination"
- Reduce the "Level of Detail" to Low (or Medium if you don't need the extra FPS)
- Disable "Motion Blur" (This is a preference, if you want it, keep it on Low)
- In the advanced tab, scroll to the Shadows section and disable "Terrain Casts Shadows" (Its about 80% down the page)
- If you want to squeeze a bit more performance, Disable "Fog Quality", though I personally prefer to keep it enabled
It looked horrendous after making the recommended changes, and F'ing one of them up. Once i Disabled LoD it was fine.so basically run it at potato settings....good job devs, you done ****** up!
And that screenshot looks horrendous.
Yeah I got mine on cdkeys back then too, mine also arrived this afternoon. Got 2 keys, think one of them was for preorder items
Thanks, sent them a mail about half an hour ago and they said they would chase it up. Just received my key(s) now, albeit the "photocopy" type layout was in German, it seems. One key for the game and the other for a pre-order bonus building.
Lol yeah i got a photocopy of some german thing with the 3 game keys lol
