And they've pulled it:UniFi OS 3.2.5 released in EA, doing a yolo and upgrading. Forgot to take a local backup like an idiot so fingers crossed.
I've not ordered from the UK store but a colleague ordered some SM patch cables from the EU store. They were fine, nothing to complain about.
Edit - You mentioned FS so I possibly incorrectly assumed you were talking about fibre patch cables. Other than DAC, I've no idea what the Ubiquiti copper patch cables are like.
Never had that issue with FS SFPs and I've been through hundreds. There's also not really such a thing as an OEM SFP - the ones with a Cisco sticker on aren't made in a Cisco factory, they are just a way to keep margins high if someone wants to offer discounts on switches.
I’m not aware of any coil whine issues and I wasn’t aware the AC Lite suffered from coil whine issues. I’ve personally sold several thousand UniFi access points and although they do fail I’ve never had a customer report any whining from an access point.I have a couple of AC Lites and both have coil whine, louder when under more load. Having moved one to a quiet room it's quite annoying. Seemingly a good excuse to upgrade... are there any issues with coil whine on U6 Lite, LR or Pro?
Following the refund on the STP U6-Pro, time to look at another one, my understanding is that the issue re the batch was small and since resolved?
Went for a 9U Penn-Elcom rack (double hinge, maybe not worth but seems goodUniFi do a nice rack but it only works with their kit, you might be able to get a shelf though. If not I highly rate Penn-Elcom racks (I have an 18U one).
SE and a switch will be fine in a cupboard.
Nice, how are you finding it?Went for a 9U Penn-Elcom rack (double hinge, maybe not worth but seems good)
Only ordered all the gear today, should arrive monday and moving into new house towards end of next week!Nice, how are you finding it?
Honestly, not sure but I'd be concerned about moisture and the cold won't be kind to HDDs if you are intending on running any.Any idea on the concerns of running in a potentially cold/freezing basement in winter?
I'd love to move my lab kit to my garage but moisture/dust/cold worries me.
Great - i've seen quite a few complain about AC Lite coil whine online but less so with other devices. Mine are quite old. I've ordered a U6-Pro anyway so will find out shortly!I’m not aware of any coil whine issues and I wasn’t aware the AC Lite suffered from coil whine issues. I’ve personally sold several thousand UniFi access points and although they do fail I’ve never had a customer report any whining from an access point.
U6 Pro now recevied. It maxes out my download speed at 600mbps and most importantly is all but silent while doing so!Great - i've seen quite a few complain about AC Lite coil whine online but less so with other devices. Mine are quite old. I've ordered a U6-Pro anyway so will find out shortly!
