- 27 Apr 2014
I will help you out some.Did not read all post after your post but I will guess people will be saying stuff like voltage too high,cpu too hot etc.Can anyone do me a favour who has a 14900K or KF and has one set at stock, Ie everything auto relating to the CPU and at stock PL limits of 253W, Auto SVID, Auto LLC basically everything Auto and MCE off and tell me what your Bios Voltage is reading and what your max voltage is peaking to in Hwinfo in Windows.
Also could you do a Cinebench run and check your clock speeds as it should not drop under 5.6ghz.
My 14900KF on my Z690 Gaming A fully updated all on Auto is giving me 1.49-1.51v in the bios and it is peaking at 1.53v! in Hwinfo in Windows and the P core clocks are dropping to 5.2ghz far cry from Intels specs of 5.6ghz and even the E cores are dropping to 4.3 from 4.4 max 65-70c during Cinebench at 253W.
Does anyone have a Strix Gaming A Z690 with 14th gen also?
My P core SP rating is giving me 108 but the E core is giving me 60! it's worse than my 12900K! I believe I have a defective chip or some of the worst dodgy silicon bodged together, I cannot find anyone with an E core SP of 60, They are all in the 70-80's range, I don't know what's going on with my chip but it should NOT be dropping clocks to 5.2 In Cinebench R23 and using 1.51v for light spiking light loads in Windows at stock.
Intel is shoving out any old silicon with 14th gen.
You do not have a defective chip.
Areas marked in blue you did not read the specifications on the intel CPU.
If you set power limit at default doing AVX benchmarks CPU clock are 5100Mhz on 14900K/KF
Auto idle voltages you have are 100% normal in BIOS for the chip unless you change something.
The 14900K/kf on auto default settings with AIO 360MM will hit 100℃ and throttle down CPU clocks on cinebench load and also can hit 370 watts on default but with your settings instant 5100Mhz cpu clock at 253w.
You may only be able to do up to P-core 5700Mhz(most likely 5500Mhz) all core and E-core 4400Mhz
What do you want to actually achieve on your CPU. To be able to run Heavy work loads EG:4D cinema or play PC games.
I think you said PC games in another post.If so take the BIOS settings I posted and use the TVB temperature offsets so you can PC game all day and if you hit a heavy workload your CPU will downclock and no one will ever know.
Also do not copy my CPU ratio offsets of 63/62/61/60 your CPU may not be able to handle that,For your SP CPU I say set 58/57/56 Core ratio P=-core and E-core 4400mhz.
Then keep it simple,use adaptive voltage or manual higher than your VF curve. SO I am guessing here your VF curve at your SP rating is probably at 5600Mhz 1.38-1.39v
5800Mhz 1.42-1.43v
So I recommend
set manual voltage at 1.45v in BIOS
set Load line calibration to 5/6
set AC/DC lines to 0.01
Set fan curve in BIOS to ramp fans higher after 40℃ to try to avoid downclocking
if you do not want to copy the tvb settings I post in the BIOS setting dump
then Intel CPUs are rated for 115℃ raise the 100℃ limit higher until you do not get downclocking on CPU
Be realistic the numbers some people spot especially on overclockers.net have freaking chillers or watercooling setups with 5 watercooling pumps and 50 fans trying to get 1℃ lower than the next guy or 1 fps more with rtx4090 running pc game benchmark 720p low settings.
Non of it is realistic at all.
What a crap wall of text lol.
, literally missed everything inbetween and went straight to a 9900k, can't see myself doing that again.
