- 27 Mar 2013
Sometimes you can get it off with a damp cloth, but we have tiles so quite a shiny surface.
"luxury" vinyl tiles (.... Plastic). So yeah think I'll do same.What kind of floor is it? I ended up using a scraper for any big bits and then the residue just wiped off
Cleaned out the bath plug hole. I used a 3d printed 'drain snake', it worked really well, much to my surprise.
It was grim. I've recently placed a cover over the plug to catch long hairs, but I'm still the one that has to clear it out every day!This job should be delegated to women (or men with long hair) given its generally them that cause the issue![]()
Maybe that was the cause.Maybe you need to trim your pubes
That, actually, makes a lot of sense.Its upside down
Pre-drive all the screws into the small end of the legs firstThat, actually, makes a lot of sense.![]()
Why when you can just get progressively more tired and angry and low on screws? Then leave half the loft unboarded with a box of unopened loft legs and 3 18mm 2.4x1.2 loft boards up there for 9 months?Pre-drive all the screws into the small end of the legs first![]()
Finally.....after 18 months this wardrobe is almost completed. In this time I did have twins then my wife died....you know, just standard stuff...
Before
During
After
I did get a structural engineer to look at removing some of the uprights, but it involved too much work and was outside the scope. Maybe when the roof gets re-done in a few decades some of them can come out.
Before
During
After
