This 100% , 11th gen was a regression in performance in most cases vs the 10900K ... 14th gen at least can't be slower than 13th gen which was not the case with 10 > 1110th to 11th gen was worse at least 14th isn’t slower than 13th
both are a poor offering if you own either a 10th or 13th gen ( i had/have both )
Shots fired, anyone agree with AMDs take.
Need to configure you AMD rig better, here is my 7800X3D/Asus B650E-E from a restart.
Hoping for some juicy Arrow Lake leaks soon. To me, 14th gen is the most disappointing and pathetic release from Intel that I can think of. Never before have they released the exact same CPU (13900k vs 14900k), as in exactly the same die, and called it a new generation.
Closest I can think of was Haswell > Devils Canyon (4770k - 4790k). That wasn't a new generation and just a refresh, but at least you got better TIM installed and higher clocks.
Also not able to get Ram clocks as high as I would have liked. I have 4x32gb sticks and was able to get them stable at 4800mhz on my 12900k, and now only at 5200mhz on the 14900k. I've seen others state that XMP works now and can achieve even 6000mhz with 128gb. Perhaps its my board but idk. Its not like I have a cheap board, although it is z690
Latest BIOS update definitely increased my boot time on my AMD rig. Not got the time with work to troubleshoot it currently, once it does boot I get the expected top tier performance with my 4090.
That sounds like it’s probably right. I have a aorus z690 xtreme. Tbh I’m not even 100% sure every game is even cool with 5200mhz. Most of what I play has exhibited 0 issues but modern warfare 3 is being very tempermental, sometimes works no problems other times acts weird and crashes with HDR on. But don’t know if that’s just the game or ram.I don't know too much about it, but general reading seems to suggest you need one of the better Z790 boards to get 64GB or more stable at speeds above ~5600 depending on latencies. Supposedly with the RAM I've got 4 sticks will do 6000 stable on the Aorus Master Z790 I'm using, potentially up to 6200 (though I think Gigabyte says 5600 for 128GB).
Yeah I can't have any less than 64gb but if realistically I'm not seeing anything worse with 128gb and can't get better with 64gb I have no reason to drop back to 64gbFrom reading up on it a lot more hit and miss - even on this Z790 board some people struggling to get over 4800MHz - though some are managing up to 6200 with 64GB and 6000 with 128GB but somewhere around 4800-5600 seems more usual.
I'd suggest starting a new thread and posting a diagram of what you've got connected where, as I'm not sure why you'd need to use a PCI-E power plug for your motherboard when the HX1000 has 2x EPS 8 pin plugs, and 8x PCI-E plugs?I have a Corsair hx1000, a 4090 and a 14900k. I had to temporarily use one of the pcie ports on my PSU to power the new link hub for the QX fans but long term I need it back for the cpu because it’s power throttling at high load with just the one cable. (Which I knew was likely to happen) Does anyone here have any potential solutions other than buying a new PSU (which I will just do if I have to) its frustrating that its all otherwise good besides just being a 6 pin PCI cable slot short.
If you must use adapters, then 2xmolex to 6 pin are the better option as they're normally better constructed and the connectors can cope with more load.I know you can get 2x sata to 6pin adaptors but that alone wouldn't be enough for the potential draw of the link hub that can be above 150w
