- 20 Oct 2002
- Oxfordshire / Bucks
Anu suggestions for best inline soap sticks for a wash brush
not sure what you mean
but you can get a wheel mitt rather than a brush which would be better
Rain this morning, did my rain X screenwash do anything? Nope, nothing!
Doesn't seem plausible that something designed to clean can also apply a coating too tbh.
My thoughts exactly
Indeed. Especially when the wiper blades are rubbing it straight off againDoesn't seem plausible that something designed to clean can also apply a coating too tbh.
Not too sureWhat would be a fair price for a detailing company to wash, decontaminate, wax and ceramic coat a medium size SUV. I was quoted £500 for the first part and £295 for the ceramic coat. Guy at the garage said ceramic coating is oversold it’s not as great as everyone tries to make you believe. PV coat the front end is the way to go, add that in I’d have been looking at £1,200
Car would be in the garage for four days
For the record it’s a 2 year old car done 11,000 miles paintwork looks okay
Yes that was it ppf coating and thanks for the linkThey're upselling you but PPF (I assume that's what they/you mean) offers more protection than a ceramic coating.
A high end coating does add hardness and protection though. https://www.gtechniq.co.uk/ceramiccoatings/
Just had to have some damage to my car fixed, which meant a large setion repainted/clear coated.
How long should I leave it before re applying some protection? I iamgine this time of year with the cold, I should probably leave it for a few weeks?
