- 23 Dec 2022
- London
Anyone playing the new Warzone? Im getting some great performance following the new update.
I upgraded my 2080ti to a 7900XTX and I have noticed a huge difference in performance so I can only imagine the increase you are seeing![]()
Wow, now THAT'S an upgrade!
Fair play being able to leave an upgrade that long. I had a big increase from my 6700k and Nvidia 1080 to my new 7800x3d and 7900xtx it's also my first Amd build and I have no regrets.
Honestly, as much as it pains me to say it, the 2080ti was feeling the same way for me and having to cut back the settings on games to hit my native refresh rate on my 1440p kind of sucked!Yeah the 1080 was really showing it's age, to the point where I was being put off gaming because the performance was getting pretty poor! It's a huge difference, allowing me to play at 1440p ultra, and handles 4K superbly well too, which is ace as I run flightsim on a big TV for immersion.
Yeh I have the same card! It's a beast hahajust purchased a 7900XTX, from a 3090. loads people want my 3090 & i really want to try a AMd card again. So was a cheapish upgrade i think (possibly) got a Sapphire Nitro X vapor
Nice, that's a good card for your mate for that money!so i posted a sms to my friends about 3090 being up for grabs & it taken in 39 secondsalthough it soldon ebay for 600-700 but sold it for 550 mates rates i also get access to SAM now, 3090 didnt support it
I asked the same question in the fsr3 thread.its weird i dont see fluid motion as an option? with latest drivers
You’re getting nearly 30k graphics score. I’d say that was amazing and on par with a XTX at stock. You are doing everything right!
lol i was looking at the 23312 ... ok i'm a little happyYou’re getting nearly 30k graphics score. I’d say that was amazing and on par with a XTX at stock. You are doing everything right!
Check the drivers. Make sure any type of vsync is off. Radeon chill needs to be off. Check your tuning profiles to make sure there is nothing going on in there.Hi all I have an issue with system performance and not sure why. Nothing has changed in my system.
7900XT, 5800X3D. Was previously getting Timespy benchmark score over 23k, now Im getting less than half that at 10k.
Ive checked all my settings and nothing appears to be different. Not used the PC for a month or so as was decorating the room so its just been switched off.
It appears from the stats that the GPU isn't clocking up to its max - average reported is only 1200MHz compared to previous runs at 2400MHz.
I ran the test earlier, got the 10k score, then updated to latest drivers, still getting 10k score.Check the drivers. Make sure any type of vsync is off. Radeon chill needs to be off. Check your tuning profiles to make sure there is nothing going on in there.
