NVIDIA 4000 Series
30 Dec 2010
Over here
Something odd I noticed, normally in desktop use my GPU fans aren't on, I noticed today they were. NVIIDA overlay report that GPU utilisation at 0% which is correct, but it's drawing 66w and clock speed is at 2625 constant.
Edit: Saw I had NVCP to max performance, disabled it, restarted and back to normal 30w/300ish mhz
mrk
mrk
Man of Honour
18 Oct 2002
South Coast
Seems a little high for idle power? My 4090 is 12 watts idle, 19 watts just dossing about web browsing/youtube etc. The average wattage reported by HWINFO is 25W over the current power on session which s a few days elapsed.
Caporegime
18 Oct 2002
Suprim is known for it tbh, hell my 4080 Trinity uses 5/6W at idle and the 4090 Suprim Liquid 46 (fans and pump are off so shouldn't be using this much)!!!! Putting me a little off keeping it tbh, gonna see if I can tweak any settings later to double-check it's right.
30 Mar 2017
I have seen my 4090FE go as low as 3.5W and it actually stays there fairly consistently, although not always that low. I think that may be due to me activating PCIE ASPM (I think that was what it was) for power saving in BIOS.
19 Feb 2007
ArcCorp
4090 Super?
lol. Someone's trolling.
It was a mistake on their site, The original source confirmed it, I highly doubt Nvidia could keep that one under wraps but let the 4070, 4070 Ti and 4080 Supers info slide out so easily.
